Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. 2017 HTC U11 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. 2017 HTC U11 Teardown, Edge Sense on HTC U11 Release Conference: adım 1, 2 resimden 1. 2017 HTC U11 Teardown, Edge Sense on HTC U11 Release Conference: adım 1, 2 resimden 2.
    • Eight Strain Gauge, two ways to access
  2. 2017 HTC U11 Teardown, Teardown begins: Heat up the Frame for easier openning: adım 2, 3 resimden 1. 2017 HTC U11 Teardown, Teardown begins: Heat up the Frame for easier openning: adım 2, 3 resimden 2. 2017 HTC U11 Teardown, Teardown begins: Heat up the Frame for easier openning: adım 2, 3 resimden 3.
    • First, for easier opening, we need to heat up the mobile frame. Please be aware of the glass cracks while heating and opening.
  3. 2017 HTC U11 Teardown, Openning: adım 3, 3 resimden 1. 2017 HTC U11 Teardown, Openning: adım 3, 3 resimden 2. 2017 HTC U11 Teardown, Openning: adım 3, 3 resimden 3.
    • We could see that there’s more glue on its frame than other phones’, this should be the reason why it can meet the requirement of IP67, to be used under water, such as taking photos while swimming or diving.
  4. 2017 HTC U11 Teardown, Inner Part: adım 4, 2 resimden 1. 2017 HTC U11 Teardown, Inner Part: adım 4, 2 resimden 2.
    • Then we reach to the part Camera
    • Finish the main part Teardown
  5. 2017 HTC U11 Teardown, Frame: adım 5, 3 resimden 1. 2017 HTC U11 Teardown, Frame: adım 5, 3 resimden 2. 2017 HTC U11 Teardown, Frame: adım 5, 3 resimden 3.
    • Here we head to the frame, it seems like there is a module on both sides of the frame
  6. 2017 HTC U11 Teardown, True Face of the Edge Sense: adım 6, 2 resimden 1. 2017 HTC U11 Teardown, True Face of the Edge Sense: adım 6, 2 resimden 2.
    • A full Teardown
    • A close-shot of the module
    • As we could see the pictures showing that each side of the frame has a module (which we did not see on other mobile devices). It has thin structure but strong and stable signal.
    • Based on the Teardown works above, we came to a conclusion, that is, Edge Sense is an "8 super-thin strain gauge” with 4 pairs of sensors on each module that separately installed on both sides of the U11 frame.
    • These strain gauges are to detect the force changing while pressing, then the signals transmitted to the CPU of mobile devices for processing, and forming a signal output.
    • It could recognize long press, short press and different level of pressure.
    • It is not by recognizing the contact of skin (or we can say not by recognizing the Capacitive sensing) while squeezing to activate this function, but by detecting the pressure of pressing to start it. Otherwise how can we initiate the Edge Sense functions underwater or when we are wearing gloves?
Gracess
303 İtibar
2 adet Kılavuz yazıldı
7 Yorum
Good teardown, Gladys. Thanks!
Paul Campbell - Yanıt
Also appreciate that you like it, thank you!;)
Gracess -
Hello,
do you know where we can find parts for repairs and replacement ?
Marco Mondragon - Yanıt
about to do my 2nd screen replacement on one of these at my shop. if i have time today ill try and photo the process of lifting out the display as it is not documented here, or anywhere else that i can find :)
Joshua Sites - Yanıt
Hey Joshua, was the screen replacement difficult? I've never worked on a phone before but I'm plenty savvy. The back replacement is super clear-cut and straightforward with all the videos on it… is the front basically the same? Thanks in advance!
Alex -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 26
Her zaman: 21,387
