Bu söküm üzerinde çalışılıyor – Son değişiklikleri görmek için düzenli olarak yenile!
Bu Teardown'da Kullanılan Aletler
  1. There are three blue LEDs to show you the power in the battery. There is also a handy LED to see what you are doing in the dark.
    • There are three blue LEDs to show you the power in the battery.
    • There is also a handy LED to see what you are doing in the dark.
  2. The bottom of the device. It's time for some prying. Take out the rubber plugs at the bottom of the device. Remove the screws which are underneath the plugs.
    • The bottom of the device.
    • It's time for some prying. Take out the rubber plugs at the bottom of the device.
    • Remove the screws which are underneath the plugs.
  3. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. use a flathead screwdriver or a spudger to pry open the device. Don't pry at the front of the device - there are a few hooks and you do not want to break them.
    • use a flathead screwdriver or a spudger to pry open the device.
    • Don't pry at the front of the device - there are a few hooks and you do not want to break them.
  5. A first glance at the inside: a big battery and the logic board.
    • A first glance at the inside: a big battery and the logic board.
    • There is a 1800 mAh battery in it.
    • There are two screws in the logic board, the battery is glued to the casing.
  6. The other side of the electronics. And the logic board.
    • The other side of the electronics.
    • And the logic board.
  7. And there it is: the A-Solar PowerBank AL-200 torn down.
    • And there it is: the A-Solar PowerBank AL-200 torn down.
    • It was easy to do.
storm
506 İtibar
2 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 Gün: 8
Son 30 Gün: 22
Her zaman: 3,354
