Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. A-Solar Power Bank AL-200 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. A-Solar PowerBank AL-200 Teardown, A-Solar PowerBank AL-200 Teardown: adım 1, 2 resimden 1. A-Solar PowerBank AL-200 Teardown, A-Solar PowerBank AL-200 Teardown: adım 1, 2 resimden 2.
    • There are three blue LEDs to show you the power in the battery.
    • There is also a handy LED to see what you are doing in the dark.
  2. A-Solar PowerBank AL-200 Teardown: adım 2, 3 resimden 1. A-Solar PowerBank AL-200 Teardown: adım 2, 3 resimden 2. A-Solar PowerBank AL-200 Teardown: adım 2, 3 resimden 3.
    • The bottom of the device.
    • It's time for some prying. Take out the rubber plugs at the bottom of the device.
    • Remove the screws which are underneath the plugs.
  3. A-Solar PowerBank AL-200 Teardown: adım 3, 2 resimden 1. A-Solar PowerBank AL-200 Teardown: adım 3, 2 resimden 2.
    • use a flathead screwdriver or a spudger to pry open the device.
    • Don't pry at the front of the device - there are a few hooks and you do not want to break them.
  4. A-Solar PowerBank AL-200 Teardown: adım 4, 1 resimden 1.
    • A first glance at the inside: a big battery and the logic board.
    • There is a 1800 mAh battery in it.
    • There are two screws in the logic board, the battery is glued to the casing.
  5. A-Solar PowerBank AL-200 Teardown: adım 5, 2 resimden 1. A-Solar PowerBank AL-200 Teardown: adım 5, 2 resimden 2.
    • The other side of the electronics.
    • And the logic board.
  6. A-Solar PowerBank AL-200 Teardown: adım 6, 1 resimden 1.
    • And there it is: the A-Solar PowerBank AL-200 torn down.
    • It was easy to do.
storm
552 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 13
Son 30 gün: 63
Her zaman: 5,375
