Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. ASUS MB169B Portable Monitor cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. ASUS MB169B Portable Monitor Teardown, Remove Faceplate: adım 1, 3 resimden 1. ASUS MB169B Portable Monitor Teardown, Remove Faceplate: adım 1, 3 resimden 2. ASUS MB169B Portable Monitor Teardown, Remove Faceplate: adım 1, 3 resimden 3.
    • In this guide you will be disassembling the ASUS portable monitor. Read Ahead and follow the directions to avoid damaging the display or clips holding it in place.
    • There are plastic clips that hold the cover in place. With a spudger insert the edge of the spudger between the faceplate and the rear cover of the monitor, as shown in the picture.
    • Slowly pry up on the faceplate starting at a corner and slowly prying along the outside edge of the faceplate and continuing around the entire cover.
  2. ASUS MB169B Portable Monitor Teardown, Remove LCD: adım 2, 3 resimden 1. ASUS MB169B Portable Monitor Teardown, Remove LCD: adım 2, 3 resimden 2. ASUS MB169B Portable Monitor Teardown, Remove LCD: adım 2, 3 resimden 3.
    • Lift the cover away from the LCD and set off to the side.
    • Remove the 4 screws holding the LCD to the back cover.
    • Do not attempt to remove the display at this time, as it is attached to the main board.
    • Turn the display over, you will see a cable connector attached to the display with yellow tape.
    • Pull up on the yellow tape to flip up the retaining bar holding the connector in place.
    • Pull the connector straight out away from the display.
  3. ASUS MB169B Portable Monitor Teardown, Remove Main Board: adım 3, 3 resimden 1. ASUS MB169B Portable Monitor Teardown, Remove Main Board: adım 3, 3 resimden 2. ASUS MB169B Portable Monitor Teardown, Remove Main Board: adım 3, 3 resimden 3.
    • Remove the four screws holding the mainpower board to the rear cover.
    • Starting at a corner use a spudger to gently pry up the main board. Work the spudger around the edges of the main board until it lifts easily.
    • Before completely removing the main board, lift up on the grey tape holding down the wires and pull it away from the back cover.
    • *Optional* You can also disconnect the wire harness if necessary, the process is the same as in Step 2.
  4. ASUS MB169B Portable Monitor Teardown, Complete: adım 4, 2 resimden 1. ASUS MB169B Portable Monitor Teardown, Complete: adım 4, 2 resimden 2.
    • This concludes the disassembly, if you wanted to replace the LCD, there are two screws connecting the board on the monitor and a wire harness.
    • You would remove these two screws and disconnect the smaller wire harness at the bottom of the LCD and then attach the board on the new LCD.
    • To reassemble, follow these steps in reverse.
  5. ASUS MB169B Portable Monitor Teardown, Additional insight: adım 5, 1 resimden 1.
    • My LCD was dropped and the power connector lifted from the main board, I used a soldering iron to resolder the connector to the board.
    • However, this did not fix the problem because the pins inside the connector were damaged. Instead of trying to resolder a new connector, I found a main board on ebay that I will use to replace it.
Brandon Adair
121 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
what is search word to get the right board at ebay
ebunoha chukwudi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 22
Son 30 gün: 168
Her zaman: 2,354
