Ana içeriğe geç
Bu teardown bir tamir kılavuzu değildir. AVerMedia GL310 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. AVerMedia GL310 Teardown, Unscrewing Screws: adım 1, 2 resimden 1. AVerMedia GL310 Teardown, Unscrewing Screws: adım 1, 2 resimden 2.
    • Use a spudger to lift the corners of the silicone membrane under the device.
    • Unscrew the Phillips head screws using a PH000 screw bit.
  2. AVerMedia GL310 Teardown, Removing The Backplate: adım 2, 1 resimden 1.
    • Lift up the backplate.
  3. AVerMedia GL310 Teardown, Removing The Motherboard: adım 3, 3 resimden 1. AVerMedia GL310 Teardown, Removing The Motherboard: adım 3, 3 resimden 2. AVerMedia GL310 Teardown, Removing The Motherboard: adım 3, 3 resimden 3.
    • Insert a plastic spudger into the highlighted notch in the motherboard.
    • Remember to use a plastic spudger or else you may short the solder joints near the notch.
    • Pull the motherboard up using the spudger.
    • Remove the motherboard, holding the corners.
  4. AVerMedia GL310 Teardown, Inspecting The Motherboard: adım 4, 2 resimden 1. AVerMedia GL310 Teardown, Inspecting The Motherboard: adım 4, 2 resimden 2.
    • Here's a list of chips present on the motherboard:
    • ITE IT6613 HDMI transmitter
    • ITE IT6604 single-link HDMI 1.4 receiver
    • Nanya NT6DM16M32BC-T1 mobile 512mb DDR RAM chip clocked at 200MHz
    • Sigma Designs PL330B-CPE3 H.264 Encoder
    • This seems to be the same chip found on the C875 model of the device
    • Texas Instruments LVC244A octal buffer/ driver
    • Nuvoton NUC100RD2BN RISC ARM microcontroller clocked at 50MHz
Marcus Jones
1.145 İtibar
6 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 525
