Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. AWEI BT Earbuds cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. AWEI BT Earbuds & Receiver Teardown, Earbud Dissasembly: adım 1, 2 resimden 1. AWEI BT Earbuds & Receiver Teardown, Earbud Dissasembly: adım 1, 2 resimden 2.
    • Remove Earbud Cushion
  2. AWEI BT Earbuds & Receiver Teardown, Secure Earbud for Separation: adım 2, 1 resimden 1.
    • Secure Earbud End (eg:Vice)
  3. AWEI BT Earbuds & Receiver Teardown, Separate Earbud Sections: adım 3, 2 resimden 1. AWEI BT Earbuds & Receiver Teardown, Separate Earbud Sections: adım 3, 2 resimden 2.
    • Using Pliers Gently Twist & Pry Away Sections, Do Not Twist more than 3-4mm
  4. AWEI BT Earbuds & Receiver Teardown, Inspect Separated Earbud Internal Wiring: adım 4, 1 resimden 1.
    • Inspect Earbud Wiring
  5. AWEI BT Earbuds & Receiver Teardown, Separate Receiver Housing: adım 5, 3 resimden 1. AWEI BT Earbuds & Receiver Teardown, Separate Receiver Housing: adım 5, 3 resimden 2. AWEI BT Earbuds & Receiver Teardown, Separate Receiver Housing: adım 5, 3 resimden 3.
    • Using a small pick or pry tool, separate Receiver Housing. Each side is secured by 3 small fragile tabs. Use the space near the micro USB opening & carefully pry to separate the 3 tabs on the opposite side.
  6. AWEI BT Earbuds & Receiver Teardown, Inspect Receiver Internal Wiring: adım 6, 3 resimden 1. AWEI BT Earbuds & Receiver Teardown, Inspect Receiver Internal Wiring: adım 6, 3 resimden 2. AWEI BT Earbuds & Receiver Teardown, Inspect Receiver Internal Wiring: adım 6, 3 resimden 3.
    • Carefully Separate the PCB to inspect the headphone's left & right earbud wiring. Cleaned up any broken connections by de-soldering, re-tinning wires & re-soldering to the PCB. Each side is labeled L + L - and R + R - the colored wire is positive and the bare wire is negative.
    • Assemble Unit in reverse order.
fugitiveALiEN
188 İtibar
1 Kılavuz yazıldı
Ekip
My Techno Guy My Techno Guy üyesi
Business
1 Üye
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 22
Her zaman: 1,584
