Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Acer Liquid E1 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Acer Liquid E1 Teardown, Acer Liquid E1 Teardown: adım 1, 1 resimden 1.
    • Remove the plastic back and the exposed battery.
    • Do not forget to remove sim- and SD-cards
    • Use a torx t5 to unscrew all screws. This will be the first and last time you'll use a screwdriver with this device.
  2. Acer Liquid E1 Teardown: adım 2, 2 resimden 1. Acer Liquid E1 Teardown: adım 2, 2 resimden 2.
    • Use a plastic opening tool or spudger
    • Pry around the side to release the backframe from the middleframe
    • Be careful as the frame is quite fragile
  3. Acer Liquid E1 Teardown: adım 3, 3 resimden 1. Acer Liquid E1 Teardown: adım 3, 3 resimden 2. Acer Liquid E1 Teardown: adım 3, 3 resimden 3.
    • To free the main board, remove the connector and antenna-cable
    • Use a plastic spudger
    • Be careful not to chip components
  4. Acer Liquid E1 Teardown: adım 4, 3 resimden 1. Acer Liquid E1 Teardown: adım 4, 3 resimden 2. Acer Liquid E1 Teardown: adım 4, 3 resimden 3.
    • Tilting the main board will reveal this connection
    • Use a plastic spudger to open the lock
    • Carefully pull the flex cable out of it
    • Don't put alot of stress on it
  5. Acer Liquid E1 Teardown: adım 5, 3 resimden 1. Acer Liquid E1 Teardown: adım 5, 3 resimden 2. Acer Liquid E1 Teardown: adım 5, 3 resimden 3.
    • At the bottom, use a pair of tweezers to remove the yellow tape from the connector
    • Use a plastic spudger to unlock
    • Pull the flexcable out carefully
  6. Acer Liquid E1 Teardown: adım 6, 2 resimden 1. Acer Liquid E1 Teardown: adım 6, 2 resimden 2.
    • Next, use a platic spudger to remove the flex cable from its connection
  7. Acer Liquid E1 Teardown: adım 7, 3 resimden 1. Acer Liquid E1 Teardown: adım 7, 3 resimden 2. Acer Liquid E1 Teardown: adım 7, 3 resimden 3.
    • Use a spudger to remove the bottom-plate from the frame.
    • Be careful when using metal tools (like I did)
    • Make sure the antenna cable isn't attached to anything except it's socket
  8. Acer Liquid E1 Teardown: adım 8, 3 resimden 1. Acer Liquid E1 Teardown: adım 8, 3 resimden 2. Acer Liquid E1 Teardown: adım 8, 3 resimden 3.
    • Let the remaining heat at 95°C for about 3-5 minutes to soften the adhesive
    • Use an opening tool to pry at the top, between your digitizer and the middleframe
    • Open it from the top, your digitizer-flex runs at the bottom
    • Be careful when using a heat-gun. Heat-guns don't distribute heat evenly and LCD-burns may occur
  9. Acer Liquid E1 Teardown: adım 9, 3 resimden 1. Acer Liquid E1 Teardown: adım 9, 3 resimden 2. Acer Liquid E1 Teardown: adım 9, 3 resimden 3.
    • To remove the LCD, remove the sticker on the back of the midframe. It conseals the LCD-flex
    • Be careful when removing the sticker. It's glued tightly and too much stress will tear the LCD-flex
    • Remove the LCD by pulling the whole cable through the midframe.
  10. Acer Liquid E1 Teardown: adım 10, 1 resimden 1.
    • All done
    • I hope you enjoyed it as much as I did
Maxim
2.297 İtibar
3 adet Kılavuz yazıldı
Ekip
iFixers Belgium iFixers Belgium üyesi
Business
1 Üye
5 adet Kılavuz yazıldı
Bir Yorum
Great Manual.. it work fine! thanks,,
JoeTech - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 23
Her zaman: 6,770
