Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
This teardown illustrates how to deconstruct the Acer MR Headset (DE). This teardown also identifies some of the components within the HMD, and is open to any edits or suggestions for unidentified elements.
Bu teardown bir tamir kılavuzu değildir. Acer Windows Mixed Reality Headset Developer Edition cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Acer Windows Mixed Reality Headset Developer Edition Specs: Two high-resolution liquid crystal displays at 1440 x 1440
    • Acer Windows Mixed Reality Headset Developer Edition Specs:
    • Two high-resolution liquid crystal displays at 1440 x 1440
    • 2.89” diagonal display size (x2)
    • Front hinged display
    • 4.00m cable
    • Built-in audio out and microphone support through 3.5mm jack
    • Single cable with HDMI 2.0 (display) and USB 3.0 (data) for connectivity
  2. Remove nose clip Pull the foam from the velcro on the headset Pull the foam from the velcro on the headset
    • Remove nose clip
    • Pull the foam from the velcro on the headset
  3. Remove the 8 Screws holding the mold to the headset Pop 4 clips on the bottom of the headset with the spudger and begin to spread the mold from the headset. 4 more clips are on the top side to fully pull off the mold
    • Remove the 8 Screws holding the mold to the headset
    • Pop 4 clips on the bottom of the headset with the spudger and begin to spread the mold from the headset.
    • 4 more clips are on the top side to fully pull off the mold
  4. Pop the top clips up with the plastic spreader. there are two clips along the front edge There is one more clip in the back corner near the lenses
    • Pop the top clips up with the plastic spreader.
    • there are two clips along the front edge
    • There is one more clip in the back corner near the lenses
  5. Release the clip along the bottom edge with the spudger. There is an opening in the side of the wall of the clip that allows room for the spudger to help separate the lens cap from the carriage Release the clip along the bottom edge with the spudger. There is an opening in the side of the wall of the clip that allows room for the spudger to help separate the lens cap from the carriage
    • Release the clip along the bottom edge with the spudger. There is an opening in the side of the wall of the clip that allows room for the spudger to help separate the lens cap from the carriage
  6. It was easier splitting the cover on the side arms open with the spudger and work your way towards the front Pop the nine clips on the top of the headset Release the bottom five clips on the headset
    • It was easier splitting the cover on the side arms open with the spudger and work your way towards the front
    • Pop the nine clips on the top of the headset
    • Release the bottom five clips on the headset
  7. Remove the four screws in the corners of  the lens Remove tape connecting the ribbon cables to the PCB Unplug the lens from the PCB
    • Remove the four screws in the corners of the lens
    • Remove tape connecting the ribbon cables to the PCB
    • Unplug the lens from the PCB
  8. Remove the four screws for the camera cable connector Remove the five screws on the PCB Remove the five screws on the PCB
    • Remove the four screws for the camera cable connector
    • Remove the five screws on the PCB
  9. Unscrew  the two screws connecting the cable to the PCB Cypress CYUSB3064-BZXC SuperSpeed USB Bridge Controller Cypress CYUSB3304-68LTXI HX3 USB 3.0 Hub
    • Unscrew the two screws connecting the cable to the PCB
    • Cypress CYUSB3064-BZXC SuperSpeed USB Bridge Controller
    • Cypress CYUSB3304-68LTXI HX3 USB 3.0 Hub
    • STMicroelectronics medium-density STM32F103C8 performance line microcontroller.
    • Spectra7 VR8050 USB 3.0 Cable Equalizer
    • Spectra7 HT8181 HDMI 2.0 Cable Equalizer
    Commented in your the HP XR headset not having a complete component identification, including those the process the cameras that make up the parallax inside/out positional tracking.
    All Things 3D - Yanıt
    It it possible to receive the board when it’s brocken?
    Sascha Kaleja - Yanıt
  10. Unscrew the 8 camera screws in the corners Cameras were not easily identifiable, however, they looked identical to the cameras we found in our HP MR HMD teardown. Also had similar part numbers to the the Microsoft Surface 3 rear camera. Cameras were not easily identifiable, however, they looked identical to the cameras we found in our HP MR HMD teardown. Also had similar part numbers to the the Microsoft Surface 3 rear camera.
    • Unscrew the 8 camera screws in the corners
    • Cameras were not easily identifiable, however, they looked identical to the cameras we found in our HP MR HMD teardown. Also had similar part numbers to the the Microsoft Surface 3 rear camera.
  11. Remove 6 screws Peal tape on the top of the films and pull back the films You can then remove the 2 high-resolution 1440x1440 liquid crystal displays.
    • Remove 6 screws
    • Peal tape on the top of the films and pull back the films
    • You can then remove the 2 high-resolution 1440x1440 liquid crystal displays.
    • Lenses: The lenses appear to be fresnel on the inside but smooth on the outside.
    The ridging on Fresnel lens is not a process. A Fresnel lens has ridges due to the way Fresnel lenses work and most are smooth on one side. So the actual description is these are Fresnel lenses with a FL approximately 35mm (don’t remember the exact number I came up with). I don’t have any of the other specs, like physical/chromatic curvature. The are also about 45mm at their widest point, making the smaller than both the Oculus and HTC/Vive lenses.
    I have not personally had a chance to review or tear-down the Samsung Odyssey, which not only have larger OLED displays, but use aspheric PMMA lenses that are part of the reason for the sharper viewing experience.
Super_All_In_One
201 İtibar
2 adet Kılavuz yazıldı
7 Yorum
This is fantastic thank you! Any plans on tearing down the other four MR headsets from Microsoft?
Connor Dolan - Yanıt
I’m curious, where are the the eye displays? And are they purchasable? I want to replace the eye display, because one in the left eye is glitching out.
Sheldon Mead - Yanıt
Hi there,
I am wondering if anyone knows the components I have highlighted.
[IMG]http://i63.tinypic.com/2hxsz1f.jpg[/IMG]
[IMG]http://i66.tinypic.com/2mm5zyu.jpg[/IMG]
[IMG]http://i63.tinypic.com/33w8hop.jpg[/IMG]
My HP WMR unit had a power surge and has burnt out most of these components.
A good electrical engineer friend of mine has cast a close eye over all the other components on the board, showing no physical damage (which I know doesn’t mean that they all ok).
I live in hope that I will be able to repair my WMR headset, as I have myself had plenty of experience with SM components.
Just identifying the values of these components is proving to be mighty tricky!
I believe (A) 6 pin “EDVGA” are voltage regulators - SOT23-6?
(B) Transistor? - “NA ID9” ?
Appreciate any help :)
Paul
Paul Slater - Yanıt
Hi !!! Led driver PAM2803
Роман Анатольевич -
Does anyone know where to buy the main cable cause I somehow broke mine pre good the cable with the USB and hdmi is the one I'm after thx
ARAA - Yanıt
Does anyone know where I could find a replacement logic board?
Jackson Korn - Yanıt
Tell me what kind of chip. C1=4C 114 in this photo https://d3nevzfk7ii3be.cloudfront.net/ig...
or in my headset C1=4A GOX
Alexey Shadrin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 99
Her zaman: 9,685
