Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Actiontec Q1000 DSL Modem cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Actiontec Q1000 Teardown, Actiontec Q1000 Teardown: adım 1, 3 resimden 1. Actiontec Q1000 Teardown, Actiontec Q1000 Teardown: adım 1, 3 resimden 2. Actiontec Q1000 Teardown, Actiontec Q1000 Teardown: adım 1, 3 resimden 3.
    • The Qwest Q1000 modem, made by Actiontec.
    • Port side with antennas detached.
    • DSL and Phone in ports
    • 4 Ethernet ports
    • USB port, reset button, and power jack
    • Not a screw in sight.
  2. Actiontec Q1000 Teardown: adım 2, 3 resimden 1. Actiontec Q1000 Teardown: adım 2, 3 resimden 2. Actiontec Q1000 Teardown: adım 2, 3 resimden 3.
    • As usual, the rubber feet are hiding screws!
  3. Actiontec Q1000 Teardown: adım 3, 3 resimden 1. Actiontec Q1000 Teardown: adım 3, 3 resimden 2. Actiontec Q1000 Teardown: adım 3, 3 resimden 3.
    • Nothing really to see here...
    • Remove the 2 antenna wires from the wifi card. One is also taped to the back of the board.
    • The circuit board is finally free!
  4. Actiontec Q1000 Teardown: adım 4, 2 resimden 1. Actiontec Q1000 Teardown: adım 4, 2 resimden 2.
    • Looks like someone was generous with the thermal paste.
    • Underneath the cover:
    • Broadcom BCM6366
    • Broadcom BCM53115
  5. Actiontec Q1000 Teardown: adım 5, 2 resimden 1. Actiontec Q1000 Teardown: adım 5, 2 resimden 2.
    • The Wi-Fi card lets down its shield...
    • The chip is a BCM4322.
  6. Actiontec Q1000 Teardown: adım 6, 2 resimden 1. Actiontec Q1000 Teardown: adım 6, 2 resimden 2.
    • The inside of the top case.
    • The antenna connectors are screwed onto the case.
  7. Actiontec Q1000 Teardown: adım 7, 2 resimden 1. Actiontec Q1000 Teardown: adım 7, 2 resimden 2.
    • The antenna connectors have gold-plated coax connectors and standard Wi-Fi antenna connectors.
    • What's underneath the heat-shrink? A ferrite bead to minimize interference.
  8. Actiontec Q1000 Teardown: adım 8, 3 resimden 1. Actiontec Q1000 Teardown: adım 8, 3 resimden 2. Actiontec Q1000 Teardown: adım 8, 3 resimden 3.
    • Testing out the light pipe with an LED throwie...
    • The light pipe takes light from tiny surface-mount LEDS on the motherboard and refracts it to the panel.
    • Here are all the LEDS:
    • 8 of the LEDS that work with the light pipe
    • One more surface mount LED
    • A white LED for illuminating the Qwest logo
    • A dual-color (red/green) LED for the WPS status indicator.
  9. Actiontec Q1000 Teardown: adım 9, 3 resimden 1. Actiontec Q1000 Teardown: adım 9, 3 resimden 2. Actiontec Q1000 Teardown: adım 9, 3 resimden 3.
    • The empty shell that once held a DSL modem.
    • The 2 detachable Wi-Fi antennas. Nothing to tear down here!
  10. Actiontec Q1000 Teardown: adım 10, 1 resimden 1.
    • Repairability score: 8/10
    • The entire device is held together with only 4 screws.
    • The Wi-Fi antenna connectors are screwed in and the cables are not soldered to the board.
    • The antennas are replaceable as well.
    • The heat sink is soldered in place, making removal difficult.
    • The Wi-Fi card is soldered in and held in place with silicon adhesive, making it impossible to remove without damaging the card or the device.
jdp23
1.312 İtibar
23 adet Kılavuz yazıldı
3Kılavuz Yorumları
Awesome teardown! These things have gotten so simple. Those antennas would be pretty easy to repurpose for something else.
Kyle Wiens - Yanıt
What are the part number, volts, and amps of the power supply?
PDXTek - Yanıt
Hello. I have one of these that I want to switch the antenna for. Are you able to tell me which of the antenna wires is the positive and neutral (I realize the antenna itself doesn’t have positive & neutral, but I don’t know the relevant term). Both wires are grey and hooked together so it’s not easy to tell
https://d3nevzfk7ii3be.cloudfront.net/ig...
earthscope - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 19
Her zaman: 6,682
