Ana içeriğe geç
Neye ihtiyacın var
Videoya Genel Bakış
Bu teardown bir tamir kılavuzu değildir. Apple Analog Watch cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Apple Analog Watch Teardown, Apple Analog Watch Teardown: adım 1, 3 resimden 1. Apple Analog Watch Teardown, Apple Analog Watch Teardown: adım 1, 3 resimden 2. Apple Analog Watch Teardown, Apple Analog Watch Teardown: adım 1, 3 resimden 3.
    • You know what time it is. (Teardown time).
    • A brief overview of the noteworthy specs and features of the Apple Watch:
    • Tells time in hours, minutes, and seconds
    • Colorful Apple logo
    • Wacky hands that will amuse and confuse your friends
    • Adjustable wrist strap
    • Sporty elastomer band option
    • Sleek chrome and anodized aluminum exterior
  2. Apple Analog Watch Teardown: adım 2, 3 resimden 1. Apple Analog Watch Teardown: adım 2, 3 resimden 2. Apple Analog Watch Teardown: adım 2, 3 resimden 3.
    • The Apple Watch fits snugly and securely around your wrist—a convenient location to keep your most important information just an arm gesture away.
    • But at the same time, the Apple Watch manages to remain unobtrusive; it doesn't bother you with unnecessary information or notifications—prioritizing what you need, ready when you need it.
    • We're already starting to get a feel for the level of craftsmanship and care that went into the design of this incredible piece of technology. The anodized aluminum buckle perfectly matches the smooth, chamfered display bezel.
    • Show your friends that you Think Different with the strikingly colorful hands, carefully selected to be as different from each other as they are from conventional watch hands—making reading the time (to the nearest 3 hours) fast and efficient.
  3. Apple Analog Watch Teardown: adım 3, 2 resimden 1. Apple Analog Watch Teardown: adım 3, 2 resimden 2.
    • The digital crown represents a crowning achievement in Apple's engineering portfolio.
    • This single knob fluidly and effortlessly combines the styling of old with the functionality of new, to bring Apple's renowned intuitiveness to your fingertips.
    • Simply pull out on the knob and rotate to adjust the time. Push it in when you're done, and Apple Watch does the rest. Interfacing with technology has never been easier.
    • Flipping the Apple Watch over, we find its fashionable and functional brushed stainless steel rear cover, featuring "Contemporary Design."
    • Apple made an excellent design choice with stainless steel—it is highly corrosion resistant, and a fairly safe alloy for people with nickel allergies, as it keeps the alloyed nickel tightly bound within its structure.
  4. Apple Analog Watch Teardown: adım 4, 2 resimden 1. Apple Analog Watch Teardown: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    $3.99
    Satın Al
    • The band is held in place with standard 18 mm spring bars, meaning replacing or upgrading your band is a simple task—provided you have the right tool.
    • We found that our angled pro tweezers work great for this—but given that the band itself is half of the fashion accessory that is Apple Watch, we're inclined to recommend a more specialized removal tool for frequent swappers.
  5. Apple Analog Watch Teardown: adım 5, 3 resimden 1. Apple Analog Watch Teardown: adım 5, 3 resimden 2. Apple Analog Watch Teardown: adım 5, 3 resimden 3.
    • Into the belly of the beast! A thin flathead screwdriver pops the rear cover off, exposing the world's first view inside an Apple Watch.
    • We're initially impressed by how much free space is left inside—perhaps Apple is future proofing the external case design, to allow for more and better features in the Apple WatchS.
    • A small plastic brace keeps the Taptic Engine and Apple S1 System-in-Package safe and secure inside the watch body.
  6. Apple Analog Watch Teardown: adım 6, 3 resimden 1. Apple Analog Watch Teardown: adım 6, 3 resimden 2. Apple Analog Watch Teardown: adım 6, 3 resimden 3.
    • Before we go any further, we'll disconnect and remove the battery, to avoid shorting out and damaging any of the internal circuitry.
    • This is an AG4 alkaline battery cell, with a typical capacity of 12-18 mAh. At 1.5 V, that's around 0.0225 watt hours.
    • Alkaline? What's up with that? Button cell batteries are typically available in alkaline or silver oxide chemistry. Silver oxide batteries are better in every way—recycleable, slower voltage drop during discharge, less leakage, and typically 50% higher capacity. Maybe we caught Apple trying to save a buck?
    • We tried to weigh the battery on our scale—and read 0.0 grams. It's probably completely weightless.
    guys, you shorten the battery in step 6 by prying it out this way!
    P Greendale - Yanıt
    Glad to see you guys have a funny sense of humor.
    tom2fixit - Yanıt
  7. Apple Analog Watch Teardown: adım 7, 2 resimden 1. Apple Analog Watch Teardown: adım 7, 2 resimden 2.
    • The digital crown interfaces with the Apple S1 computer via a long stem, locked in place. Depressing this tiny lever releases the crown and stem for further scrutiny.
  8. Apple Analog Watch Teardown: adım 8, 1 resimden 1.
    • With the crown removed, the display and internals are easy to remove. Thanks to a non-fused display, if you crack your display glass, you'll be able to replace just the glass without buying a new display.
    • The exterior case, a sporty aluminum, is certainly one of the most interesting components of this Apple Watch.
    • With that, we'll set the internals aside for a moment and see what more we can learn about the ins and outs of the outside of the Apple Watch.
  9. Apple Analog Watch Teardown: adım 9, 3 resimden 1. Apple Analog Watch Teardown: adım 9, 3 resimden 2. Apple Analog Watch Teardown: adım 9, 3 resimden 3.
    • Combining the best of both worlds, our version of the Apple Watch features a chrome-plated stainless steel body, sandwiched in stylish anodized aluminum rings.
    • While the rear ring is press fit onto the body, and snaps on and off, the front doubles as a retaining ring for the display glass, and is adhered in place.
    • A bit of careful prying is all that's needed to lift it up and off, decorative rivets and all.
    This is totally and completely Steve Jobs. R.I.P.
    George A. - Yanıt
  10. Apple Analog Watch Teardown: adım 10, 2 resimden 1. Apple Analog Watch Teardown: adım 10, 2 resimden 2.
    • With the front bezel removed, we're able to safely extract the glass.
    • While the fancier stainless steel and gold variants of Apple Watch come with sapphire crystal, we personally favor this high-tech aluminosilicate Ion-X glass.
    • Compared with sapphire, it's both lighter and more resistant to impact. Throw your hands in the air, Apple Watch don't care!
    • The chamfered edge fits in the body to make a tight seal, giving this watch its IPXX water resistance rating.
    • We'll be holding out for the Apple Watch SCUBA Edition, which is waterproof to 500 meters and can suggest seafood recipes based on nearby wildlife, according to rumors that we personally made up.
  11. Apple Analog Watch Teardown: adım 11, 3 resimden 1. Apple Analog Watch Teardown: adım 11, 3 resimden 2. Apple Analog Watch Teardown: adım 11, 3 resimden 3.
    • The display looks amazingly sharp. Even at ultra-close range, we can't see the pixels.
    • In fact it almost looks like an e-ink display. Even without a battery, the watch still displays the image that was on screen when we depowered it.
    • As we begin dismantling the display components, we're pleased to note Apple has revived the uber-Newtonian rainbow logo of the 70s, 80s, and 90s.
  12. Apple Analog Watch Teardown: adım 12, 3 resimden 1. Apple Analog Watch Teardown: adım 12, 3 resimden 2. Apple Analog Watch Teardown: adım 12, 3 resimden 3.
    • Back in your cage! We set the internals back into the body while we're working on them.
    • In classic apple fashion, the best tricks are known only to their repair techs.
    • We tried to operate on the internals on a table, but almost cracked the display. Turns out the case acts as a perfect repair bench, evenly distributing pressure.
    • Look, ma—no jewels! We didn't really expect to find jewel bearings in an Apple Watch anyway.
    • These screws are so tiny, it just makes no cents.
  13. Apple Analog Watch Teardown: adım 13, 3 resimden 1. Apple Analog Watch Teardown: adım 13, 3 resimden 2. Apple Analog Watch Teardown: adım 13, 3 resimden 3.
    • We've made our way to the brains of the Apple Watch—the Apple S1 microcomputer, including:
    • Ultra low-power microcontroller
    • Quartz crystal, operating at 32,768 Hz
    • When power is applied to the crystal, it oscillates 32,768 times a second, filling a counter register in the processor. When the register fills, it overflows back to 0, triggering a pulse of the motor—and one second on the second hand.
    • This incredible processing power is capable of maintaining time accurate to within 1 second per day!
  14. Apple Analog Watch Teardown: adım 14, 2 resimden 1. Apple Analog Watch Teardown: adım 14, 2 resimden 2.
    • Next to come out: the stator coil.
    • The timekeeping apparatus is powered by a Lavet stepping motor. This single coil, controlled by the microcontroller to swap its polarity back and forth, rotates the motor armature.
    • The times, they are a-changin'.
  15. Apple Analog Watch Teardown: adım 15, 2 resimden 1. Apple Analog Watch Teardown: adım 15, 2 resimden 2.
    • Taking care not to sneeze, we tweeze out the rotor/drive gear.
    • Snuggled up against a penny, this drive gear looks quite inconsequential, but the rotor's permanent magnet enables it to rotate 180 degrees with each pulse of the coil.
    • Extreme miniaturization means this watch draws very little power—with this configuration, it should last years on a single charge. Apple's claim of "all-day battery life" seems a mite conservative.
  16. Apple Analog Watch Teardown: adım 16, 3 resimden 1. Apple Analog Watch Teardown: adım 16, 3 resimden 2. Apple Analog Watch Teardown: adım 16, 3 resimden 3.
    • The intermediate wheel transfers power from the rotor to the gear train.
    • From here, ousting the second gear, and the rest of the gear train, is cake.
    • The final gear incorporates three concentric shafts to independently control each part of the display.
  17. Apple Analog Watch Teardown: adım 17, 3 resimden 1. Apple Analog Watch Teardown: adım 17, 3 resimden 2. Apple Analog Watch Teardown: adım 17, 3 resimden 3.
    • We carefully remove the final pieces—the motor stator and click spring.
    • As we should expect from Apple's design team, the included click spring provides haptic feedback every second, keeping you up to date on the continual passage of time.
    • This is literally the most advanced Apple Watch that we've had the pleasure of tearing down.
  18. Apple Analog Watch Teardown: adım 18, 3 resimden 1. Apple Analog Watch Teardown: adım 18, 3 resimden 2. Apple Analog Watch Teardown: adım 18, 3 resimden 3.
    • Apple Watch Repairability Score: 9 out of 10 (10 is easiest to repair)
    • The rear case is easy to remove.
    • No adhesive is used anywhere in the Apple Watch, and a combination of Phillips screws and spring contacts makes disassembly fairly easy.
    • The super-standard 18 mm watch band is removable and replaceable—with a wealth of custom options.
    • Non-fused display means the glass can be replaced separately, greatly decreasing cost of repair for a cracked screen.
    • No manufacturer-supplied repair manual.
61 Yorum
Where can I get this?
gladgura - Yanıt
eBay. Expect to pay through the nose!
mpias -
Nice one! Does it tell you the date?
John Chapman - Yanıt
Absolutely wonderful Apple. A true 10 out of 10 and well done iFixit for making April 1st such a great day with this superbly produced guide
chrisflowers - Yanıt
Nice April's fool. ;–)
Nicolas Zbinden - Yanıt
I will buy one \o/
Elie - Yanıt
Lol, I fell for it. Stupid me!
Kaleb - Yanıt
Real cute! Where do I get my "hands" on one?
Geoffrey - Yanıt
The best Apple Watch repair guide yet.
Jan Sondergaard - Yanıt
That was brilliant. I would expect nothing but the best from you guys.
Michael - Yanıt
You guys are on a roll today :-)
philw - Yanıt
April's fool!
Guy's you're the very best on earth.... I've been caught of course
Erik DUFOUR - Yanıt
best. teardown. ever.
alexrg - Yanıt
hahaha, i really was expecting the latest 2015 iWatch.. Tricked me too :-)
Yves - Yanıt
Lots of fun, but it looks like April Fool..
bobgus99 - Yanıt
Touché guys...touché. How did I not see this coming? I haven't a clue. :)
Americanstang - Yanıt
Thanks iFixit! This saved me hours at the genius bar waiting to fix my apple watch. I managed to replace my Mickey Mouse face with the one displayed here in 30 minutes. Slight problem...all the parts stopped moving, so it displays the time correctly twice daily.
Stephen - Yanıt
I fell for it until 25 seconds into the video, I should have scrolled down.
Derek Mellot - Yanıt
I trusted you and you betrayed that trust. You betrayed me. Isn't betrayal fun?!
John Oliver - Yanıt
Fooled Me Not.
Weldon Smith - Yanıt
April fools!! Where the real iwatch tear down?
ocalaselltech - Yanıt
Soooo Im guessing an April fools day joke? Still looked better then the real Apple watch lol
radarrecords - Yanıt
Ha! You got me! (Note the date.)
G David Frye - Yanıt
Yeah great, and I have a bridge for sale that spans Sydney Harbour, Australia. Interested?
Ken Wloodall - Yanıt
Ha ha, very clever! I hope you were able to put the timepiece back together as it was before since it has been considered a collector's item. =)
Andjeo Ruzo - Yanıt
Oh you! :-P
gordonchild - Yanıt
Very good friends very good
Archangel - Yanıt
Nice one, lol
Mac o PC - Yanıt
Funny! I love it!
peterzarrella - Yanıt
April Fools! Good one - ya got me!!
Susan - Yanıt
Very nice! I was like browsing apple website looking for this model duh!!!
Goncalo Girao - Yanıt
This is glorious.
Numitron - Yanıt
So where can I get that watch? I kinda like it.
Eric Hyland - Yanıt
Unapologetically plastic!
drleeds - Yanıt
Isn't that a collectible you just tore apart? :D
jhjh - Yanıt
This joke LOL
ArM - Yanıt
Perfect execution! I love it!
Jackson Bloomston - Yanıt
You got me again. Nice one.
I still remember how I fell for the last years April's fool. lol
shoeib - Yanıt
Good one!! Loved the iFaxit email I got too. Funny stuff. BTW, the iFaxit page will actually fax you a guide when you click on the button and submit a real fax number.
kev1 - Yanıt
Nice...could you fax me a copy of the teardown video?
roysmith1959 - Yanıt
An apple device with a removable battery!!n I never thought I wouls see one!!!
jamesiturnbull - Yanıt
You guys are awesome ! Took me a couple of minutes to realize what day this is !
jsjae1 - Yanıt
That is not the apple watch
David Walters - Yanıt
Hehehehe, well it is April 1st. Nice to see one of the classic Apple watches.
macdoctornorwich - Yanıt
Omg, you guys are the worst. (I watched the whole video, non the less, lol). Oh and the iFaxit email.. I thought it was true.. I was like, "what? why??" Until now.
mrrmz - Yanıt
http://originalapplewatch.com is still selling these for the lucky few!
applewatcher - Yanıt
Good to see Apple returning to mechanical gears & moving parts. So much more reliable than that solid state junk they've been churning out lately.
pijin - Yanıt
Got me, too. Seemed a little odd that the new Apple Watch worked a lot like my Timex.
sheldon - Yanıt
Since it's April 1 I expected a joke and wasn't disappointed. Good one! Still, I appreciate the teardown. I have two of these watches and they both need batteries. Now I can do it myself instead of taking them to a jeweler.
By the way, I hope you can get this thing back together again, because they're going for a bundle on eBay!
mpias - Yanıt
You got me too, actually made me smile. I actually thought ifaxit was real, I was so confused lol
richcouture - Yanıt
Aaaaaaaah! I guess it's time to get an  Watch!!!
Asri - Yanıt
Although I enjoyed this April Fool's Day joke, the watchmaker in me cringed at seeing the hands removed with a pair of blunt-nosed tweezers. For future tear-downs,please invest in a set of hand levers or a Presto hand remover! I'll also point out that plastic crystals really should only be removed(and installed) by using a compression tool. A set of spring bar tools(either levers or the tweezer type) are preferred for removing the band spring bar, and a purpose-made watch case knife really should be used to open the back. I speak from personal experience, as I have scars from using both a screwdriver and a CaseXX(pocket knife) to open watch case backs.
And, with that I'll quit being pedantic and appreciate this for what it is :)
ben10ben2 - Yanıt
"Fool me once, shame on you. Fool me twice, shame on me."
- Scotty (from the original Star Trek cast)
Allan Miller - Yanıt
Great April fools! The best part of the joke is how they keep calling a slotted screwdriver a flat head screwdriver and even sell them on their website as flathead screwdrivers. There are several types a flat head screws. Wouldn't you use a Philips screwdriver to remove a flat head Phillips screw? A Robertson (square) to remove a flat head Robertson screw? Why do they keep calling a Slotted screwdriver a flat head screwdriver? Get the terminology correct.
Tom Connor - Yanıt
I actually still have mine. The stem knob has lost most of its plating and is a bit corroded but the watch still works.
Thankfully, I haven't had to expose it to Yosemite which would have totally fubar'd it.
barryjaylevine - Yanıt
That looked like an awful lot like a retrofitted Tandy TRS-80 eWatch, I'm just say'n.
mark - Yanıt
Is this supposed to be funny? Stick to what you do best, iFixIt. This was awful.
Casey Hendley - Yanıt
Take this down, it's not April fools anymore and this was more disappointing than funny.
Chris D - Yanıt
I think this is actually a "Mac™OS" watch :-). There was an Apple Watch though. I have a few pictures on flickr:
https://www.flickr.com/photos/nbeadman/s...
Nick Beadman - Yanıt
I’m not even mad, this was actually really interesting.
Sandy34 - Yanıt
Go ahead; re-assemble it and make it work. :lol:
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 30
Her zaman: 139,559
