Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Apple DVI to ADC Adapter cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Apple DVI to ADC Adapter Teardown, Remove Sticker Screw Cover: adım 1, 3 resimden 1. Apple DVI to ADC Adapter Teardown, Remove Sticker Screw Cover: adım 1, 3 resimden 2. Apple DVI to ADC Adapter Teardown, Remove Sticker Screw Cover: adım 1, 3 resimden 3.
    • Turn the device upside down so that the information printed on the back is visible.
    • Carefully peel the sticker using a screwdriver from an edge. This will reveal two Phillips screws.
  2. Apple DVI to ADC Adapter Teardown, Bust the Plastic Housing Open: adım 2, 3 resimden 1. Apple DVI to ADC Adapter Teardown, Bust the Plastic Housing Open: adım 2, 3 resimden 2. Apple DVI to ADC Adapter Teardown, Bust the Plastic Housing Open: adım 2, 3 resimden 3.
    • Begin to open from the cable side. Carefully lift the side up like you would a hinge. The clips should un-clip themselves.
    • There are plastic clips that hold the casing together on the other side.
  3. Apple DVI to ADC Adapter Teardown, Removing the Shielded PSU: adım 3, 3 resimden 1. Apple DVI to ADC Adapter Teardown, Removing the Shielded PSU: adım 3, 3 resimden 2. Apple DVI to ADC Adapter Teardown, Removing the Shielded PSU: adım 3, 3 resimden 3.
    • Remove all four screws on the edges of the PSU.
    • To remove the last screw, remove the shielding tape.
    • Be careful not to pull on the PSU too hard. there is a connection to the logic board.
    • Carefully peel the shielding tape to release the PSU from it's place
  4. Apple DVI to ADC Adapter Teardown, Release the PSU and Deshield the Logic Board: adım 4, 3 resimden 1. Apple DVI to ADC Adapter Teardown, Release the PSU and Deshield the Logic Board: adım 4, 3 resimden 2. Apple DVI to ADC Adapter Teardown, Release the PSU and Deshield the Logic Board: adım 4, 3 resimden 3.
    • Pull the shield towards the cable side and it should pop open. (Some force is required).
    • Disconnect the PSU connector.
    • PSU is free.
  5. Apple DVI to ADC Adapter Teardown, Removing the Logic Board: adım 5, 1 resimden 1.
    • Unscrew the logic board and pull it out
alienozi
146 İtibar
1 Kılavuz yazıldı
Bir Yorum
Great teardown and history lesson! I didn’t know what ADC was—a proprietary Apple interpretation of DVI. Apple hasn’t changed a bit, for better or worse. The world is a better place for it though :)
iEvan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 27
Her zaman: 2,158
