Neye ihtiyacın var
First. remove the C retaining clip by gently pushing the sides away from the connector with your thumbs, then pull the cable away from the board, not up
Remove the 2 Phillips screws
Next, gently remove the board from the drive, minding the cable running beneath
In addition to tray, lift out other components as pictured
Disconnect cables from black connector so motor and other components can be removed from chassis
Remove side rails by pulling up gently. Each rail has two plastic poles that sit in the body. In this attempt, each rail lost a pole that snapped off. Poles seemed to be glued down
Because the side screws were previously removed, the black front of the drive can come off. Our drive's LED was tested and worked, but was faint. Feel free to test yours first. If working, skip the next step
Our LED was removed from the front case by removing the pictured ring with the help of a flathead screwdriver. Take your time so the front of the case isn't damaged and nothing besides the ring comes off
With the case stripped and a new LED purchased, the fun begins!
The only major changes to the case are outlined in rectangles. The metal chassis was milled down to match the height of the bottom of the disk entry area on the black front plate. This lined up well with our Apple SuperDrive (pulled from a MacBook Pro)
The wood block was added for support underneath the SuperDrive
The rails fit nicely around the SuperDrive when re-installed
A new LED was purchased and soldered to the LED connector from a 2.5" USB to SATA board, and then inserted snugly into the front of the case (may not be necessary if your LED lights up well)
With LED cabled routed, and 2.5" hard drive placed in cavity underneath
Dremeled into the back plate for USB cables to route through
Picture 1: optical drive installed into body
Picture 2: SATA to USB cable for optical drive (plug and play on macOS. A right angle cable was purchased but a straight cable would be preferable due to the amount of space at the back, as pictured)
Picture 3: hole to thread SATA to USB cable through for 2.5" hard drive
The original 'latch' slides out easily without the original components, so it was left out
Run out of case to 4-port USB adaptor (possible to install inside case if a hole could be cut out)
With the drive connected to a Mac over USB (hub is enough to power both OD and SATA drive over one cable) we can insert and eject DVDs with ease!
To re-assemble, replace all body Phillips screws
Enjoy your vintage look with up to date tech!
10 Yorum
that is so freaking cool!
Thanks! Hope others try it.
Jon -
OH MY GOSH THIS IS SO AMAZINNNNGGG!!! Thanks for making the guide! Now I just need to get an Apple Disk II haha, amazing.
Acquired! Can’t wait!
I don’t have that device yet , where can I buy it? , and does it support USB 2.0? , and how does it get electricity for the engine?
What device? What engine?
Jon -
Apple Floppy Disk Subsystem could be found on *b@y.. But.. it is often sold in a very high price or with original Apple classic PC
Turtle -
Nice haven't seen an apple floppy drive in years I used them in elementary school that is cool what you did to it
Thus demonstrating that once upon a time, Apple products were actually repairable.
