Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Apple Studio Display M2454 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Apple Studio Display M2454 Teardown, Apple Studio Display M2454 Teardown: adım 1, 1 resimden 1.
    • Notice that the main components of the monitor are only accessible from the back of the device.
  2. Apple Studio Display M2454 Teardown: adım 2, 1 resimden 1.
    • Locate the four hex head screws located on the corners of the back panel.
    • Remove the screws with a 2mm hex screwdriver.
  3. Apple Studio Display M2454 Teardown: adım 3, 1 resimden 1.
    • Remove the clear and gray back panels.
  4. Apple Studio Display M2454 Teardown: adım 4, 1 resimden 1.
    • Remove the three screws with #2 phillips head screwdriver.
  5. Apple Studio Display M2454 Teardown: adım 5, 1 resimden 1.
    • To remove the metal panel, push towards the bottom of the monitor to release its clips and pull the panel away.
  6. Apple Studio Display M2454 Teardown: adım 6, 1 resimden 1.
    • Remove screw holding the plastic bracket with #2 Phillips head screwdriver.
  7. Apple Studio Display M2454 Teardown: adım 7, 1 resimden 1.
    • Remove the four screws on the metal bracket.
  8. Apple Studio Display M2454 Teardown: adım 8, 1 resimden 1.
    • Remove the two philips head hold-down screws with the #2 Phillips head screwdriver.
  9. Apple Studio Display M2454 Teardown: adım 9, 1 resimden 1.
    • Remove black connector by pushing the end of the tab closest to the wiring and pulling away from board.
  10. Apple Studio Display M2454 Teardown: adım 10, 1 resimden 1.
    • Remove white connector by lifting tab and pulling away from board.
    • Be careful when lifting tabs, they break easily.
  11. Apple Studio Display M2454 Teardown: adım 11, 1 resimden 1.
    • Remove connector connected to the hold down previously removed simply by pulling with hand.
  12. Apple Studio Display M2454 Teardown: adım 12, 1 resimden 1.
    • Now that the main computer cable is detached, remove it away from monitor.
  13. Apple Studio Display M2454 Teardown: adım 13, 1 resimden 1.
    • Remove the two screws holding the USB port in place with #2 Phillip's head screwdriver.
  14. Apple Studio Display M2454 Teardown: adım 14, 1 resimden 1.
    • Remove the screw on the wire hold down with #2 Phillips head screwdriver.
  15. Apple Studio Display M2454 Teardown: adım 15, 1 resimden 1.
    • Remove white connector connected to LCD main board by lifting tab with tool and pulling away from board.
  16. Apple Studio Display M2454 Teardown: adım 16, 1 resimden 1.
    • The USB port is now detached, remove it from monitor.
  17. Apple Studio Display M2454 Teardown: adım 17, 1 resimden 1.
    • Remove connector on the left bottom corner of the LCD main board by simply pulling with hand.
  18. Apple Studio Display M2454 Teardown: adım 18, 1 resimden 1.
    • Remove the connector on the bottom right corner by 1st removing tape first and pulling with hand.
  19. Apple Studio Display M2454 Teardown: adım 19, 1 resimden 1.
    • Remove top right connector of the LCD main board by pulling with hand.
  20. Apple Studio Display M2454 Teardown: adım 20, 1 resimden 1.
    • Remove the final connector of the LCD main board by pulling with hand.
  21. Apple Studio Display M2454 Teardown: adım 21, 1 resimden 1.
    • Remove the four screws on each corner of the main board with #2 Phillips head screwdriver.
  22. Apple Studio Display M2454 Teardown: adım 22, 1 resimden 1.
    • The board is now detached, remove it from monitor.
  23. Apple Studio Display M2454 Teardown: adım 23, 1 resimden 1.
    • Locate the top and bottom connector on the CCFL inverter and remove it by inserting pin into the small holes and pulling away.
    • This step may be easier with two people.
  24. Apple Studio Display M2454 Teardown: adım 24, 1 resimden 1.
    • Remove the two screws on the top and bottom of the CCFL inverter with #2 Phillips head screwdriver.
  25. Apple Studio Display M2454 Teardown: adım 25, 1 resimden 1.
    • The CCFL inverter is now detached, remove it from monitor.
  26. Apple Studio Display M2454 Teardown: adım 26, 1 resimden 1.
    • You have now successfully taken apart a Apple Studio Display M2454.
Dylan Perry
177 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-27, Maness Winter 2010 Cal Poly, Team 13-27, Maness Winter 2010 üyesi
CPSU-MANESS-W10S13G27
4 Üyeler
9 adet Kılavuz yazıldı
3 Yorum
This model is also known as the Apple Studio Display 15" LCD.
analogcd - Yanıt
excellent wee guide......i came here in my search for a replacement stand for this model.
bobby nailen - Yanıt
Failing caps were the main problem with this — no air flow.
Mal - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 26
Her zaman: 7,589
