Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Apple Universal Dock Model A1256 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Apple Universal Dock Model A1256 Teardown, Apple Universal Dock Model A1256 Teardown: adım 1, 1 resimden 1.
    • Pry along the edge of the bottom of the case. It will just pop out.
  2. Apple Universal Dock Model A1256 Teardown: adım 2, 1 resimden 1.
    • Remove the top case from the bottom.
  3. Apple Universal Dock Model A1256 Teardown: adım 3, 1 resimden 1.
    • There are five Phillips screws holding the metal brace down (In the picture I have already removed them).
  4. Apple Universal Dock Model A1256 Teardown: adım 4, 2 resimden 1. Apple Universal Dock Model A1256 Teardown: adım 4, 2 resimden 2.
    • The brace is glued in near the ir-sensor. You may have to apply a little bit force to remove it, but it will come out with just pulling. (You can pry it a little bit with a spudger or a screwdriver)
  5. Apple Universal Dock Model A1256 Teardown: adım 5, 2 resimden 1. Apple Universal Dock Model A1256 Teardown: adım 5, 2 resimden 2.
    • The only major chip located on the circuit board. (All those who have wondered about the dock's line out, I think we are clear now.)
Devilac
67 İtibar
1 Kılavuz yazıldı
Bir Yorum
Can the actual dock insert (the section the iPod would clot on top of) be used in an Apple iPod HiFi repair? (see repair article Apple iPod Hi-Fi iPod Dock Inserts Replacement)
Harrison C - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 41
Her zaman: 24,643
