Giriş
A look inside the Arlo Ultra 2 Security Camera.
Neye ihtiyacın var
Features:
4K Video with HDR
Color Night Vision
Integrated Spotlight
180° Viewing Angle
Crystal Clear 2-Way Audio
Weather Resistant
Advanced SmartHub
With the camera face plate removed, we get our first look at some of the components that make up the Arlo Ultra Security Camera
Spot Light LEDs (400 lumens)
Infrared Light LEDS
TDK ICS-41350 Microphone
Left Side, Light Detector. Right Side, Multi-Color LED
Speaker / Siren - NG521-0015-01B18100010711
With the Camera Face Plate removed, use the Spudger Tool to pry the Camera Assembly away from the Camera Body
Once the Camera Assembly comes loose from the Camera Body, use the Spudger Tool to pry against the two plastic tabs on the bottom of the Camera Assembly that hold the Camera Assembly to the Camera Body PCB (Main PCB)
Pull the Camera Assembly away from the Assembly Body
The Camera Assembly is held in place by Zero Insertion Force Connectors to the Main PCB in the Camera Body
Now that the Small PCB has been removed, we can review the components on the PCB. Some parts could not be crossed referenced. Please leave a comment if you happen to know a part or parts.
Small PCB Topside
U1 Part Markings: 3070, TI 861, AXLY
Small PCB Backside
U24 Part Markings: PA81, TI 686, A6KS
U5 Part Markings: 18M
With the Large EMI / Heatsink Shield removed, we can now remove the Flex PCB that contains the Microphones, Light Detector, Multi-Color LED and PIR Sensor
Use a pair of Long Needle Nose Pliers to pull the Metal Shield Tape from the backside of the Camera Assemble Body.
From the frontside of the Camera Assembly Body, pull the Metal Shielding Tape through the hole to the backside of the Camera Assembly Body
Use the Spudger Tool to gently pry out the Flex PCB. The Flex PCB is held in place by double stick foam tape
The Speaker / Siren can also be removed after the Metal Shield Tape has been removed by pulling the speaker cable through the hole between the backside and frontside of the Camera Assembly Body that was occupied by the Metal Shield Tape
With the Metal Shield Tape removed and the Foam Tape scraped off, the components on Flex PCB can be reviewed
Light Detector
Multi-Color LED
The Flex PCB has foam tape on both sides, and a Rubber Cavity Cap that surrounds each Microphone. The Foam Tape, and Rubber Cavity Caps can be removed to allow a close up view of the Microphones
Frontside and Backside Close up Views of the Right Side Microphone on the Flex PCB
Close Up View of the 4K Image Sensor PCB. The Image Sensor has no part number that could be cross referenced. Leave a comment, if you know the part number of the Image Sensor.
Close Up View of the backside of the Image Sensor PCB
U4 Part Markings: PA81, TI 878, A5X3
Please leave a comment if you know the part number for U4
Close Up View of the Camera Lens
Main PCB Front Side Close Up View. Please leave a comment if you know information about U5, U41,U37,U24, U32
U5 Part Marking: 1200, P68, AC5F
U41, U37, U24 Part Markings: PA81, TI 878, A5X2
U32 Part Marking: GT, 43, 828
Main PCB Backside Close Up View. Please leave a comment if you know information about U1, U26, and U42
U1 Part Markings: OA00805-B56G, TIVH62. Appears to be the video image processor
U7 - Cypress Ultra-Low Power, 802.11a/b/g/n WiFi/BLuetooth 5.0 Controller
U26, and U42 Part Markings: PA61, TI 871, A241, and 851DD, TI 838, A827
RF Front end with RF Switches, RF Bandpass Filter, and possible a RF PA
Dual WiF / Bluetooth Antennas
7 Yorum
I would like to know if its possible to buy the camera lens, anyone know?
I also need a lens. I have one camera that broke a lens when it fell.
Stephen -
Even I also have the same question regarding the camera lens.I have another query to add on that I have two Arlo Ultra home security cameras.
I have purchased them for a couple years ago.I am facing an issue concurrently about the “Arlo Camera Offline Error”.I have tried out all the manuals as directed arlo security camera review .Guide us what we have missed out?
I also have a camera that shows offline after the battery died. I can’t get it to reconnect even with other batteries. It won’t charge a battery and there is no LED activity either.
Stephen -
See last two comments. I had two cameras with different issues so I thought I would swap the lens across. The one with the broken lens is also offline now. So still no solution.
Also the Arlo online support has not been responding even when I’m logged in. So not sure what the warranty is worth.
