Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Asus Chromebit CS10 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Asus Chromebit CS10 Teardown, Asus Chromebit CS10 Teardown: adım 1, 3 resimden 1. Asus Chromebit CS10 Teardown, Asus Chromebit CS10 Teardown: adım 1, 3 resimden 2. Asus Chromebit CS10 Teardown, Asus Chromebit CS10 Teardown: adım 1, 3 resimden 3.
    • The top image is the Chromebit with dust cap on its box next to a standard Sharpie for scale.
    • The circled screw in the second image is the write-protect screw, if you remove this and reassemble the Chromebit, if you boot in Developer Mode you are able to unlock the software write-protect and modify/replace the system firmware.
    • Using an iFixit spudger in the USB port stand it up to increase the gap to the sides of the USB port where you can insert a second spudger or a guitar pick and run it down each of the sides of the Chromebit to pop the case loose.
dragon788
708 İtibar
3 adet Kılavuz yazıldı
Ekip
ComputerPhreaks ComputerPhreaks üyesi
Business
1 Üye
2 Yorum
How did you get this open? I’ve been using the spudger with out any luck. Is the case glued on by any chance? Thanks
Jimbo - Yanıt
If you turn the end of the spudger sideways to get it started you should be able to undo the clips around the edges with a guitar pick. There is some resistance from the thermal pad.
dragon788 -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 18
Her zaman: 1,589
