Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Asus ZenWatch 3 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Asus ZenWatch 3 Teardown, Let's begin: adım 1, 1 resimden 1.
    • Tools needed T5 screwdriver
  2. Asus ZenWatch 3 Teardown, Band Removal: adım 2, 2 resimden 1. Asus ZenWatch 3 Teardown, Band Removal: adım 2, 2 resimden 2.
    • Remove pins securing the band
  3. Asus ZenWatch 3 Teardown, Open the body: adım 3, 1 resimden 1.
    • Remove the four screws
  4. Asus ZenWatch 3 Teardown: adım 4, 1 resimden 1.
    • Pry open at the side near the rose gold ring
  5. Asus ZenWatch 3 Teardown: adım 5, 1 resimden 1.
    • The battery would be automatically disconnected
  6. Asus ZenWatch 3 Teardown: adım 6, 1 resimden 1.
    • Battery
  7. Asus ZenWatch 3 Teardown: adım 7, 1 resimden 1.
    • Remove ribbons connected to the board
  8. Asus ZenWatch 3 Teardown: adım 8, 1 resimden 1.
    • Complete disassembly
Reon
141 İtibar
1 Kılavuz yazıldı
20 Yorum
I'm excited to find out if the middle button is actually a digital crown and whether or not there is NFC. This was built for wear 2.0 after all.
Joseph White - Yanıt
Is it possible to also see a picture of the chip side of the PCB? Would like to see how the 2100 is designed into the board
Jan Gaudestad - Yanıt
Does anybody know how the third button can be replaced? I lost it. Thank you in advance for any help.
splatdom - Yanıt
What should I do if the power button doesn’t work?
MichaelKing10or - Yanıt
I took mine apart for this very thing. The other buttons clearly click, but the middle button was kind of mushy. I don’t see a way to easily remove the button from the circuit board. However, in looking it over, I found that if the circuit board is pressed firmly while pressing the power button, it does get the thing to click. Upon reassembly, I found this to still be true. When the power button doesn’t work, if I squeeze the watch, face to back, and at the same time press the button, it makes contact.
Brodie Krause -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 40
Her zaman: 14,461
