Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Audio-Technica ATH-M50x cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Audio-Technica ATH-M50x Teardown, Remove Foam Earpads: adım 1, 3 resimden 1. Audio-Technica ATH-M50x Teardown, Remove Foam Earpads: adım 1, 3 resimden 2. Audio-Technica ATH-M50x Teardown, Remove Foam Earpads: adım 1, 3 resimden 3.
    • Unfold the headphones face up for easy access to the Foam Earpads.
    • Insert index finger underneath foam, pinch foam between thumb and index and slowly ease the compression fitting out of its track.
    • Repeat same process for right Earpad.
  2. Audio-Technica ATH-M50x Teardown, Remove Speaker Plate: adım 2, 3 resimden 1. Audio-Technica ATH-M50x Teardown, Remove Speaker Plate: adım 2, 3 resimden 2. Audio-Technica ATH-M50x Teardown, Remove Speaker Plate: adım 2, 3 resimden 3.
    • Remove four J1 screws.
    • Carefully lift plate to avoid putting any strain on the internal wiring. Note that connections are soldered.
    • Make sure to free the speaker wire from W shaped spring before setting the Speaker plate next to the headphone assembly.
  3. Audio-Technica ATH-M50x Teardown, Remove Speaker Housing and Speaker: adım 3, 3 resimden 1. Audio-Technica ATH-M50x Teardown, Remove Speaker Housing and Speaker: adım 3, 3 resimden 2. Audio-Technica ATH-M50x Teardown, Remove Speaker Housing and Speaker: adım 3, 3 resimden 3.
    • Unscrew the three remaining J1 screws.
    • Lift speaker retainer away from speaker.
    • The speaker now comes away easily from the speaker plate.
  4. Audio-Technica ATH-M50x Teardown, Repeat steps 2 and 3 for Left Earpiece: adım 4, 1 resimden 1.
    • To remove speakers will require soldering skill.
Broske
181 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 48
Son 30 gün: 190
Her zaman: 9,874
