Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Basis B1 Fitness Tracker cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Basis B1 Fitness Tracker Teardown, Basis B1 Fitness Tracker Teardown: adım 1, 3 resimden 1. Basis B1 Fitness Tracker Teardown, Basis B1 Fitness Tracker Teardown: adım 1, 3 resimden 2. Basis B1 Fitness Tracker Teardown, Basis B1 Fitness Tracker Teardown: adım 1, 3 resimden 3.
    • Technical Specifications
    • 1 MHz RISC 16 Bit MicroController, Active Mode @ 400uA
    • Ultra Low-Power Consumption at Standby Mode @ 1.3uA, and Off-Mode with RAM Retention @ 0.22uA
    • Sensors onboard: Optical blood flow; Galvanic Skin response (perspiration), Ambient Temperature, Body Temperature, 3-Axis Accelerometer
    • First, you begin by taking off the straps. . If you have taken out a watch strap before, it is a similar method
    • Flip the watch, use the plastic opening tool and slide into end of the strap, then push the spring contacts until the strap just breaks away from its catch
    • Independent electrodes to possibly modulate AC Signal onto your skin and measure at the receiving end. Possibly measuring impedance (thereby knowing how much you sweat)
  2. Basis B1 Fitness Tracker Teardown: adım 2, 3 resimden 1. Basis B1 Fitness Tracker Teardown: adım 2, 3 resimden 2. Basis B1 Fitness Tracker Teardown: adım 2, 3 resimden 3.
    • Unscrew the four screws at the back of the watch, then gently use the spudger to open it
  3. Basis B1 Fitness Tracker Teardown: adım 3, 2 resimden 1. Basis B1 Fitness Tracker Teardown: adım 3, 2 resimden 2.
  4. Basis B1 Fitness Tracker Teardown: adım 4, 3 resimden 1. Basis B1 Fitness Tracker Teardown: adım 4, 3 resimden 2. Basis B1 Fitness Tracker Teardown: adım 4, 3 resimden 3.
    • You see the gap in between here? That gap exist where the LCD sits beneath the MCU board.
    • Using a bit of highly precise de-soldering technique (left quite a few melted marks btw), you have to desolder the 4 contact points in order to separate the board from the LCD panel
    • P/S: Credit to my peer who helped me out. Fortunately it wasn't me. Else I would have left quite a larger mess :)
  5. Basis B1 Fitness Tracker Teardown: adım 5, 2 resimden 1. Basis B1 Fitness Tracker Teardown: adım 5, 2 resimden 2.
    • 1st Temperature Sensor (Texas Instruments) TMP112 marked as OBS. This might be one of the sensors that detects the ambient temperature as it is positioned away from the human body
    • Thanks to Luis Filipe Rossi for identifying the external SOT563 temperature sensors
    • 25P32V6G - ST 32MB NOR Serial Flash Memory
    • Analog Devices - ADXL335B, 3-Axis Accelerometer
    • Freescale MPR121 Proximity Capacitive Touch Sensor Controller (for the 4 capacitive touch buttons) as listed at this site & pictured here
    • MSP430xG461x- Texas Instruments MSP430 family of ultralow-power mixed signal microcontroller. Built-in Temperature Sensor.
    • Unknown 31939591322
    • Unknown H852 3N47
  6. Basis B1 Fitness Tracker Teardown: adım 6, 1 resimden 1.
    • I'm quite interested of what they have done here. Instead of doing their own RF design, they employed a module design. Too bad there is no way to give the RF Module company any publicity Edit - the module is BT23 from ampedrf
    • Cortex M3 - STM32F103C6; Low-density performance line, ARM-based 32-bit MCU with 16 or 32 KB Flash, USB, CAN, 6 timers, 2 ADCs, 6 communication interfaces. Built-in temperature sensor here
    • Unknown 2500D8, 90MT323 Bluetooth Transceiver Chip
    • Chip Antenna
  7. Basis B1 Fitness Tracker Teardown: adım 7, 3 resimden 1. Basis B1 Fitness Tracker Teardown: adım 7, 3 resimden 2. Basis B1 Fitness Tracker Teardown: adım 7, 3 resimden 3.
    • The wire bonded Optical Blood Flow Sensor (under a magnifying glass) with the two LED
    • 2nd Temperature Sensor (Texas Instruments) TMP112 marked as OBS. This might be one of the sensors that detects the body temperature as it is positioned nearer to the human body
  8. Basis B1 Fitness Tracker Teardown: adım 8, 1 resimden 1.
    • The Basis B1 Tracker was an easy device to disassemble. Apart from the de-soldering process, it could quite be a minimal effort.
    • That's it, leave more comments below if you would like to have more additional details of the specific part you are interested in.
Denz Choe
1.333 İtibar
2 adet Kılavuz yazıldı
4 Yorum
I don't see any mention of USB on the MSP430's data sheet, so those two unknown chips *might* be a USB-serial bridge and an EEPROM for the VID/PID/etc. They're right next to what seems to be an oscillator too.
I didn't separate the boards on mine so I couldn't get a good look, but my battery was marked: Cyber-Power CYL-352426 3.7V, 190mAh
Shea Clifford - Yanıt
perfect,Well done!
keen - Yanıt
Quick comment, the temperature sensors used in the device are not the ones embedded in the microcontrollers but the 2 TMP112. These are the ICs with SOT563 package marked as OBS.
Luis Filipe Rossi - Yanıt
Thanks Luis!, I will update the page shortly. PS; you can update this page too. I've set edit reputation to 0 should the general public discover more information than me
Denz Choe -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 8,147
