Ana içeriğe geç
Bu Teardown'da Kullanılan Aletler
Giriş
The only tools needed are a philips screwdriver and a narrow putty knife.
Bu teardown bir tamir kılavuzu değildir. Belkin Express Dock cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. View of the connectors
    • View of the connectors
  2. Use a putty knife to remove the four rubber feet.  Once removed, there are 4 phillips screws to be removed. Use a putty knife to remove the four rubber feet.  Once removed, there are 4 phillips screws to be removed.
    • Use a putty knife to remove the four rubber feet. Once removed, there are 4 phillips screws to be removed.
  3. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  4. The next step is to use the putty knife to pry off one of the two plastic endcaps, they snap out and the circuit board slides out.
    • The next step is to use the putty knife to pry off one of the two plastic endcaps, they snap out and the circuit board slides out.
  5. Use the phillips screwdriver to remove 5 more screws to remove the plastic mounting frame.
    • Use the phillips screwdriver to remove 5 more screws to remove the plastic mounting frame.
  6. Front and back of the board. From left to right on the front of the board the major chips are:  LSI FW643E-02 (FIreWire800); Broadcom BCM57762 (gige); Intel L150I56 (Thunderbolt controller), NXP LPC1114F (two), Fresco FL1100 (USB3); C-Media CM119A (Audio)
    • Front and back of the board.
    • From left to right on the front of the board the major chips are: LSI FW643E-02 (FIreWire800); Broadcom BCM57762 (gige); Intel L150I56 (Thunderbolt controller), NXP LPC1114F (two), Fresco FL1100 (USB3); C-Media CM119A (Audio)
    • From left to right on the back of the board the major chips are: Parade PS161HDM; Parade PS8301 (two); NXP ZSD310 (two); Parade PS8321. The chips seem to support HDMI/DVI conversion and Display Port!
  7. close-ups of the major chips close-ups of the major chips close-ups of the major chips
    • close-ups of the major chips
thompsonfamily
217 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 10
Son 30 Gün: 31
Her zaman: 4,012
