Giriş
Belkin WeMo Switch teardown.
Neye ihtiyacın var
Model: F7C027
FCC ID: K7SF7C027
Input: 120 V, 15 A, 60 Hz
Output: 120V, 15 A, 60 Hz
Components on the motherboard:
Ralink RT5350 Wi-Fi SoC
Winbond W9825G6JH-6 256 Mb 166 MHz SDRAM
Macronix MX25L12835EMI-10G 128 Mb NOR Flash Memory
Momentary push button switch for factory reset
Momentary push button switch for power switch
5 Yorum
I notice that’s a 240V 10amp relay they’ve used. Do you think there is any electrical difference (aside from the plug pattern) between the US 110V version and the EU/Australian 220V one?
Thanks, also here 2 of them after little use: The exterior on off button had come loose and was rattling around inside. Very poor quality now I have opened them. Guess need to try and glue them back on.
