Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Beyer Dynamic DT290 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Beyer Dynamic DT280/DT290 Microphone Teardown, Remove the Ear Pad: adım 1, 1 resimden 1.
    • The ear pad is held to the ear piece by 4 plastic clips. Gently pull the ear pad away from the ear piece to remove.
  2. Beyer Dynamic DT280/DT290 Microphone Teardown, Remove the Speaker: adım 2, 1 resimden 1.
    • Remove the speaker driver by removing the screws above and below.
  3. Beyer Dynamic DT280/DT290 Microphone Teardown, Remove white plastic clip: adım 3, 1 resimden 1.
    • Remove the white plastic clip with a plastic prying tool. It's likely that it is stuck down with some low tack adhesive.
  4. Beyer Dynamic DT280/DT290 Microphone Teardown, Remove Blue Clip: adım 4, 1 resimden 1.
    • By pushing the blue clips towards the centre with a prying tool or something similar, the microphone boom arm is then released from the body of the ear piece.
  5. Beyer Dynamic DT280/DT290 Microphone Teardown, Remove the boom arm: adım 5, 3 resimden 1. Beyer Dynamic DT280/DT290 Microphone Teardown, Remove the boom arm: adım 5, 3 resimden 2. Beyer Dynamic DT280/DT290 Microphone Teardown, Remove the boom arm: adım 5, 3 resimden 3.
    • To remove the boom arm, it must be de-soldered from the PCB
Chris Moore
121 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 26
Her zaman: 863
