Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. BlackBerry 8700c cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. BlackBerry 8700c Teardown, BlackBerry 8700c Teardown: adım 1, 1 resimden 1.
    • In this first step you will remove the battery cover by pushing down on the button on the cover and sliding towards the bottom of the phone.
    • To do this unscrew all four T6 screws
    • Once this is done gently remove the back cover of the phone by pulling first from the bottom towards you, then from the top upwards.
  2. BlackBerry 8700c Teardown: adım 2, 1 resimden 1.
    • To remove the battery, place your fingernail in the slot at the top right of the battery and pull up.
  3. BlackBerry 8700c Teardown: adım 3, 3 resimden 1. BlackBerry 8700c Teardown: adım 3, 3 resimden 2. BlackBerry 8700c Teardown: adım 3, 3 resimden 3.
    • Next, remove the back portion of the phone by removing four T6 Screws.
    • Once the screws have been removed, firmly grab the back cover and pull back from the front cover.
  4. BlackBerry 8700c Teardown: adım 4, 2 resimden 1. BlackBerry 8700c Teardown: adım 4, 2 resimden 2.
    • To remove the middle portion of the phone you will again remove four T6 screws.
    • Follow the removal of the screws, you can now pull the front face plate away from the middle portion.
  5. BlackBerry 8700c Teardown: adım 5, 2 resimden 1. BlackBerry 8700c Teardown: adım 5, 2 resimden 2.
    • Follow the removal of the screws, you can now pull the middle portion away from the main logic board.
    • Next, hold the logic board and remove the front face plate of the phone
  6. BlackBerry 8700c Teardown: adım 6, 2 resimden 1. BlackBerry 8700c Teardown: adım 6, 2 resimden 2.
    • When the front face plate has been pulled away, be sure to grab the keypad as it may fall out.
  7. BlackBerry 8700c Teardown: adım 7, 2 resimden 1. BlackBerry 8700c Teardown: adım 7, 2 resimden 2.
    • Next, use a metal spudger to unhook the earpiece from the inside of the front panel.
  8. BlackBerry 8700c Teardown: adım 8, 3 resimden 1. BlackBerry 8700c Teardown: adım 8, 3 resimden 2. BlackBerry 8700c Teardown: adım 8, 3 resimden 3.
    • Using a metal spudger, push back on the four clips holding the LCD screen to the logic board.
    • Next gradually pull the screen away from the board so that none of the clips are engaged.
    • Last, use a metal spudger to push back on the clip locking in the ribbon cable for the screen.
  9. BlackBerry 8700c Teardown: adım 9, 1 resimden 1.
    • The screen is now fully detached, and the phone is completely disassembled.
k3nt
42 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-4, Maness Fall 2009 Cal Poly, Team 18-4, Maness Fall 2009 üyesi
CPSU-MANESS-F09S18G4
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 6,570
