Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Parçalar
Hiçbir parça belirtilmedi.
    • I grab this video from Youtube, its show very clear how to open the top and the back panel. Please watch until 2min
  1. Unscrew the white box cover in the back, 4 screws. Remove the white box cover, and then careful lift the electronic board as the picture
    • Unscrew the white box cover in the back, 4 screws.
    • Remove the white box cover, and then careful lift the electronic board as the picture
    • Look for two line, one white and one black on the bottom. They should be connect to the electronic board through 2 connectors
    • Cut that two lines
  2. LCD iPhone Ekran Tamir Kit'leri
    Ömür Boyu Garantimiz kapsamındaki bütçe seçeneği.
    Shop Kits
    Onarım maliyetlerini düşürün, kaliteyi değil.
    Shop Kits
  3. Unscrew and take out the dial Take out the outer burr
    • Unscrew and take out the dial
    • Take out the outer burr
    • Unscrew 4 screws
    • Take out the motor
  4. Unscrew 4 screws Carefull lift the part with motor up.
    • Unscrew 4 screws
    • Carefull lift the part with motor up.
  5. Examine the gear. In my case, I found one strange object, sticked on the gear wall. Look like it is a washer pressed with gear teethes. Good to take it out but I wonder where it came from? In my case, I found one strange object, sticked on the gear wall. Look like it is a washer pressed with gear teethes. Good to take it out but I wonder where it came from?
    • Examine the gear.
    • In my case, I found one strange object, sticked on the gear wall. Look like it is a washer pressed with gear teethes. Good to take it out but I wonder where it came from?
  6. Unscrew this, remember follow the clock wise If you just want to replace worn out impeller: hold the limiter steady, unscrew (red square) with clock wise, take out the inner burr. And try to clean and replace the impeller while holding the limiter! You should ask some body to help with this step. Take the Limiter out. Take care because it go with 6 balls and 6 springs! Perform this step only if you think there are some wrong with the Limiter (Big crack sound when grind )
    • Unscrew this, remember follow the clock wise
    • If you just want to replace worn out impeller: hold the limiter steady, unscrew (red square) with clock wise, take out the inner burr. And try to clean and replace the impeller while holding the limiter! You should ask some body to help with this step.
    • Take the Limiter out. Take care because it go with 6 balls and 6 springs! Perform this step only if you think there are some wrong with the Limiter (Big crack sound when grind )
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
thanhlp
193 İtibar
1 Kılavuz yazıldı
Bir Yorum
Hi, could you please tell me from where can I buy Breville BCG820BSS1BCA1 gear/limiter, the one which is in step 6. it’ll be big help.
my email is hbk.singhvi@gmail.com
sandeep singhvi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 36
Son 30 gün: 148
Her zaman: 1,283
