Neye ihtiyacın var
Öne Çıkan Belge
Place casing on the side, allowing for the removal of the Sliding mechanism frame, LED strip cover and a heat vent grill on the opposite side
Detach sliding mechanism frame, by inserting a flat head screwdriver pulling towards the frame, unfolding the 6 metal pieces, releasing the sliding mechanism frame along with the LED strip cover. Which can be pulled out using the flat head screwdriver, with no pressure required
To access the second circuit board, and shielded electronic components, use a Phillips head screwdriver, to unscrew the two Philips head screws in place, holding the shielded electrical component module
The shielded module housing will lean back away from the interior components, removing the one Philips head screw, will provide access to the screws on the bottom holding the components
