Ana içeriğe geç
Brother PT-90 Personal Labeler Disassembly
Neye ihtiyacın var
  1. Brother PT-90 Personal Labeler Disassembly, Brother PT-90 Personal Labeler Disassembly: adım 1, 2 resimden 1. Brother PT-90 Personal Labeler Disassembly, Brother PT-90 Personal Labeler Disassembly: adım 1, 2 resimden 2.
    • Start with your device off. The screen should be blank and not displaying anything.
    • Turn the device over so it's resting face down.
    • You should be able to see the model name of the label-maker, as well as a window in which you can view the label cartridge.
  2. Brother PT-90 Personal Labeler Disassembly: adım 2, 3 resimden 1. Brother PT-90 Personal Labeler Disassembly: adım 2, 3 resimden 2. Brother PT-90 Personal Labeler Disassembly: adım 2, 3 resimden 3.
    • Using your thumb, press in and then upward on the fastener at the top of the device. The back of the device should come off easily.
    • Remove the 4 batteries located on the left side of the device.
  3. Brother PT-90 Personal Labeler Disassembly: adım 3, 3 resimden 1. Brother PT-90 Personal Labeler Disassembly: adım 3, 3 resimden 2. Brother PT-90 Personal Labeler Disassembly: adım 3, 3 resimden 3.
    • To remove the label cartridge from the device, use a plastic opening tool from your iFixit tool kit.
  4. Brother PT-90 Personal Labeler Disassembly: adım 4, 3 resimden 1. Brother PT-90 Personal Labeler Disassembly: adım 4, 3 resimden 2. Brother PT-90 Personal Labeler Disassembly: adım 4, 3 resimden 3.
    • Attach the J1 Screwdriver Bit to the extension tool from your tool kit.
    • Remove all of the screws from the back of the device.
  5. Brother PT-90 Personal Labeler Disassembly: adım 5, 2 resimden 1. Brother PT-90 Personal Labeler Disassembly: adım 5, 2 resimden 2.
    • Once the screws have been removed, press as shown on the fastener.
    • Carefully open the device.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Tessa Hathaway
148 İtibar
1 Kılavuz yazıldı
Ekip
University of Maine, Team 2-1, Diaz Fall 2016 University of Maine, Team 2-1, Diaz Fall 2016 üyesi
UMAINE-DIAZ-F16S2G1
3 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 23
Her zaman: 794
