Giriş
This is a full teardown of Gamestop's new CANDY CON wireless controller for the Nintendo Switch and PC. This controller operates as a bluetooth switch pro controller on the NS setting and a PC dongle wireless controller using the PC mode.
Key features include:
Customizable face plates
Customizable D-pad
Customizable Joysticks
Bluetooth 5.2
USB Dongle
USB C Charging
Analog triggers
Hall effect joysticks
Rechargeable 600mAh battery
2 Rear Programmable buttons
Macros and Turbo Mode
Neye ihtiyacın var
Locate the indentation on the bottom of the controller
Pull the faceplate off using a fingernail or spudger
Remove both joysticks and the D-pad by carefully pulling up
Remove 8 Phillips screws with a Philips #1 screwdriver
Pry open the two main pieces by pulling up on the edges of the controller
Separate the controller by flipping it on its face and then prying up near the bottom buttons
Unscrew the 2 Phillips #1 screws securing the mainboard to the controller housing
Carefully remove the mainboard and attached haptic motors by pulling it up from the bottom and then top
All buttons are keyed so they can only go in the exact spot they belong
Follow the teardown guide in reverse to reassemble the controller
When reassembling the controller align the bottom buttons first and then work on the charging port side
Test all the buttons before or right after screwing in the mainboard
The D-pad has an arrow on the top that should point up (towards the arrow on the base controller)
