Ana içeriğe geç
CR-10 V2 Print Head Teardown
Neye ihtiyacın var
  1. CR-10 V2  Print Head Teardown, Teardown: adım 1, 3 resimden 1. CR-10 V2  Print Head Teardown, Teardown: adım 1, 3 resimden 2. CR-10 V2  Print Head Teardown, Teardown: adım 1, 3 resimden 3.
    • Make sure all power cables to your 3D Printer are unplugged including wall plugs (A/C) and/or USB cables.
    • Using M2 hex remove the 3 button head screws holding the print head to the X carriage plate.
    • Using M2 hex, remove the 4 screws holding the hot end fan in place (2 screws attach to the front half and the other to the rear)
    • Using M2 hex, remove 3 button head screws that secure front and rear sections together. Do not try to pull apart yet!
  2. CR-10 V2  Print Head Teardown, Teardown: adım 2, 3 resimden 1. CR-10 V2  Print Head Teardown, Teardown: adım 2, 3 resimden 2. CR-10 V2  Print Head Teardown, Teardown: adım 2, 3 resimden 3.
    • Using M2 hex, remove the 2 button head screws securing the part cooler fan. 1 attaches to the front and the other to 2 rear.
    • Pull the front half off to expose the rear section and hot end.
    • Now, treat it like an E3D V6 hot end. However, the nozzle is not V6 style.
    • The stock nozzle is MK8 just like standard CR-10/ CR-10S
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Tiny Machines 3D
3.019 İtibar
14 adet Kılavuz yazıldı
Ekip
Tiny Machines 3D Tiny Machines 3D üyesi
Community
5 Üyeler
41 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 63
Her zaman: 8,445
