Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Canon PowerShot S400 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Canon PowerShot S400 Teardown, LCD Screen: adım 1, 2 resimden 1. Canon PowerShot S400 Teardown, LCD Screen: adım 1, 2 resimden 2.
    • Unless stated otherwise, use a Phillips #00 screwdriver to remove all screws.
    • On the backside of the camera, remove the 4.75 mm screw that sits at the top right corner.
    • Remove the four 4.75 mm screws that sit at the bottom of the camera.
  2. Canon PowerShot S400 Teardown: adım 2, 1 resimden 1.
    • On the side of the camera, remove the two 4.75 mm screws that sit near the USB digital terminal.
  3. Canon PowerShot S400 Teardown: adım 3, 3 resimden 1. Canon PowerShot S400 Teardown: adım 3, 3 resimden 2. Canon PowerShot S400 Teardown: adım 3, 3 resimden 3.
    • On the side of the camera, remove the four 4.75 mm screws that sit near the wrist strap mount.
    • Remove the two small metal plates, which the four screws hold in place.
    Mel Moss - Yanıt
  4. Canon PowerShot S400 Teardown: adım 4, 2 resimden 1. Canon PowerShot S400 Teardown: adım 4, 2 resimden 2.
    • When removing the casing, do not drop the small black plastic piece. This piece sits in a small gap above the lens, to the left of the flash, and underneath the camera case.
    • Remove the small black plastic piece and set it aside. If necessary, use tweezers to remove the small black plastic piece.
    • Detach the front case and back case.
    Suggest adding an image to show which piece the guide is referring to. It is difficult to understand without the camera.
    Change the following directions to: "If necessary, use a tweezers to carefully remove the small black plastic piece."
    Mel Moss - Yanıt
  5. Canon PowerShot S400 Teardown: adım 5, 1 resimden 1.
    • Do not remove the metal plate this step refers to. Removal at this step may damage the ribbon cable. Wait until the next step to remove the plate.
    • Remove the 3.5 mm screw that sits on the metal plate at the bottom of the camera.
    • Remove the two other 3.5 mm screws that sit on the side, to the left of the screw you just removed.
    • In the image, we have already removed some of the screws.
  6. Canon PowerShot S400 Teardown: adım 6, 3 resimden 1. Canon PowerShot S400 Teardown: adım 6, 3 resimden 2. Canon PowerShot S400 Teardown: adım 6, 3 resimden 3.
    • A ribbon cable attaches to the metal plate and to the main circuit board, on the front of the camera.
    • Gently release the black latch.
    • Remove the ribbon cable and metal plate assembly.
  7. Canon PowerShot S400 Teardown: adım 7, 2 resimden 1. Canon PowerShot S400 Teardown: adım 7, 2 resimden 2.
    • On the backside of the camera, remove the 3.5 mm screw that sits to the left of the viewfinder and above the LCD screen.
    • Remove the second 3.5 mm screw that sits directly above the LCD screen.
    • Gently detach the ribbon cable.
  8. Canon PowerShot S400 Teardown: adım 8, 1 resimden 1.
    • Locate the ribbon cable on the main circuit board, which sits below the lens.
    • Gently release the black latch on the ribbon cable connector and detach the ribbon cable.
  9. Canon PowerShot S400 Teardown: adım 9, 2 resimden 1. Canon PowerShot S400 Teardown: adım 9, 2 resimden 2.
    • Remove the LCD screen and set it aside.
  10. Canon PowerShot S400 Teardown, Motherboard: adım 10, 1 resimden 1.
    • On the main circuit board, gently release the black latches of the four ribbon cables.
    • Gently detach the ribbon cables.
  11. Canon PowerShot S400 Teardown: adım 11, 2 resimden 1. Canon PowerShot S400 Teardown: adım 11, 2 resimden 2.
    • Detach the white-capped and green-capped wires, which sit near the flash.
  12. Canon PowerShot S400 Teardown: adım 12, 1 resimden 1.
    • Using a spudger, gently detach the shutter button assembly from the camera.
  13. Canon PowerShot S400 Teardown: adım 13, 1 resimden 1.
    • Remove the four 3.5 mm screws that hold the main circuit board.
    • Do not remove the main circuit board yet.
  14. Canon PowerShot S400 Teardown: adım 14, 2 resimden 1. Canon PowerShot S400 Teardown: adım 14, 2 resimden 2.
    • Do not completely remove the main circuit board from the camera. A soldered ribbon cable still attaches the board to the camera. Complete removal would break the soldering points.
    • In a hinge-like motion, gently lift the bottom of the main circuit board, which is the side without the soldering points.
    • Gently detach the white ribbon cable from the underside of the main circuit board.
  15. Canon PowerShot S400 Teardown: adım 15, 2 resimden 1. Canon PowerShot S400 Teardown: adım 15, 2 resimden 2.
    • Do not attempt this next step unless you have soldering experience and feel comfortable desoldering. Otherwise you may damage the camera.
    • Gently desolder the two ribbon cables attached to the motherboard.
    • Remove the motherboard.
  16. Canon PowerShot S400 Teardown, Canon PowerShot S400 Teardown: adım 16, 2 resimden 1. Canon PowerShot S400 Teardown, Canon PowerShot S400 Teardown: adım 16, 2 resimden 2.
    • This step exposes the flash capacitor, a black cylindrical object, that is a part of the flash assembly. The capacitor can cause electrical shock.
    • Working with the lens-flash assembly, remove the three 3.45mm screws located on the metal plate.
    • Separate the flash assembly from the lens assembly.
    • Set aside the flash assembly.
  17. Canon PowerShot S400 Teardown: adım 17, 1 resimden 1.
    • A ribbon cable prevents complete separation of the viewfinder and the lens assembly.
    • Remove the three 2.5mm screws connecting the viewfinder to the rest of the lens assembly.
  18. Canon PowerShot S400 Teardown: adım 18, 1 resimden 1.
    • Remove the three 2.5mm screws underneath the flex circuit.
  19. Canon PowerShot S400 Teardown: adım 19, 1 resimden 1.
    • Remove the small 1.5mm screw attaching the metal plate to the lens assembly.
  20. Canon PowerShot S400 Teardown: adım 20, 1 resimden 1.
    • Displayed here are all of the components of the camera.
    • To reassemble the camera, follow all of the steps in reverse order.
Justin
133 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 5-19, Amido Winter 2011 Cal Poly, Team 5-19, Amido Winter 2011 üyesi
CPSU-AMIDO-W11S5G19
4 Üyeler
6 adet Kılavuz yazıldı
2 Yorum
FYI My S400 would not start sometimes. If I banged it in the palm of my hand occasionally it would then work. I was also having terrible trouble with batteries not working and showing low charge when they had been charged.. I opened it up as a last resort. On the front left side below the shutter button there was a small ribbon cable that under a magnifying glass I could see was slightly out of line. I reseated it and the camera has acted flawlessly since.
dwoodusa90069 - Yanıt
Am curious - I do not see the “Sensor” in this teardown? My immaculate S400 never dropped, not a scratch or scuff-mark, suddenly stopped working - dead sensor. The shutter still works and it can play images taken on another camera. But the display is near-black in record mode and images taken are “pure black”. It literally went from perfect to dead in one power-cycle. I was wondering if something may have come loose in there that a tear-down would identify?
TheDesertsweeper - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 29
Her zaman: 7,091
