Giriş
This guide outlines the steps in tearing down your camera to its basic components.
Neye ihtiyacın var
On the backside of the camera, remove the 4.75 mm screw that sits at the top right corner.
Remove the four 4.75 mm screws that sit at the bottom of the camera.
Remove the small black plastic piece and set it aside. If necessary, use tweezers to remove the small black plastic piece.
Detach the front case and back case.
On the main circuit board, gently release the black latches of the four ribbon cables.
Gently detach the ribbon cables.
Working with the lens-flash assembly, remove the three 3.45mm screws located on the metal plate.
Separate the flash assembly from the lens assembly.
Set aside the flash assembly.
2 Yorum
FYI My S400 would not start sometimes. If I banged it in the palm of my hand occasionally it would then work. I was also having terrible trouble with batteries not working and showing low charge when they had been charged.. I opened it up as a last resort. On the front left side below the shutter button there was a small ribbon cable that under a magnifying glass I could see was slightly out of line. I reseated it and the camera has acted flawlessly since.
Am curious - I do not see the “Sensor” in this teardown? My immaculate S400 never dropped, not a scratch or scuff-mark, suddenly stopped working - dead sensor. The shutter still works and it can play images taken on another camera. But the display is near-black in record mode and images taken are “pure black”. It literally went from perfect to dead in one power-cycle. I was wondering if something may have come loose in there that a tear-down would identify?
