Giriş
This guide will instruct you on the complete disassembly of the Caterpillar B15.
Neye ihtiyacın var
Place the phone screen-side down and place thumb on the yellow and black switch. Slide the switch to the right to unlock the back covering for removal.
With the back cover removed, locate and remove the Phillips screw pictured top-center, and the two torx screws above and to either side of the Phillips screw. A T-5 bit is required for removal of the torx screws.
WARNING: Proceeding beyond this point will void the warranty for this device.
2 Yorum
Hi,
where can i buy T5 Torx screws for CAT B15 ?
Regards,
Laurent NOEL
Any idea where I can get the rubber piece that covers the USB port? The one repair shop in the US wants about $200 for that repair.
