Ana içeriğe geç
Bu teardown bir tamir kılavuzu değildir. Christmas tree cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Christmas Tree Teardown, Christmas Tree Teardown: adım 1, 1 resimden 1.
    • The teardown shows a christmas tree Nano, but should you have a bigger - Classic one, you may follow these steps - upscaling everything.
  2. Christmas Tree Teardown: adım 2, 2 resimden 1. Christmas Tree Teardown: adım 2, 2 resimden 2.
    • First order of business: presents!
    • Use caution and joy when opening your presents.
  3. Christmas Tree Teardown: adım 3, 2 resimden 1. Christmas Tree Teardown: adım 3, 2 resimden 2.
    • Disconnect the power plug
    • Remove the power socket, should there be one on your tree.
  4. Christmas Tree Teardown: adım 4, 1 resimden 1.
    • To remove the baubles, lift them gently and untangle the string from the branch.
  5. Christmas Tree Teardown: adım 5, 3 resimden 1. Christmas Tree Teardown: adım 5, 3 resimden 2. Christmas Tree Teardown: adım 5, 3 resimden 3.
    • If you find a capacitor on your christmas tree, straighten its leads to detach it.
    • All discrete electronic elements should be removed in this manner.
  6. Christmas Tree Teardown: adım 6, 1 resimden 1.
    • Protective hand-wear may come in handy.
  7. Christmas Tree Teardown: adım 7, 1 resimden 1.
    • Remain gentle, even when an element is very difficult to untangle.
  8. Christmas Tree Teardown: adım 8, 2 resimden 1. Christmas Tree Teardown: adım 8, 2 resimden 2.
    • To remove the top ornament, lift it upwards.
  9. Christmas Tree Teardown: adım 9, 1 resimden 1.
    • Finally, remove the lights.
    • Begin with the light that was placed as the last. If you are uncertain, start from the topmost one.
  10. Christmas Tree Teardown: adım 10, 2 resimden 1. Christmas Tree Teardown: adım 10, 2 resimden 2.
    • Before you run around barefoot in celebration, clean up.
    • Check amongst the floor sweepings for any surface mount components components which may have gone missing during assembly, and carefully put them aside
    • The christmas tree is disassembled!
    • Check whether your local council will take your old Christmas tree for recycling. Burning is not recommended on account of the CO2 emissions it would produce.
    • Thank you for reading, hope you are having a happy holiday.
    • Fix yourself a wonderful New Year in 2019!
baq
305 İtibar
3 adet Kılavuz yazıldı
Bir Yorum
skuirel sed it good!
Kyle Wiens - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 8,646
