Neye ihtiyacın var
Use the Phillips #1 Screwdriver to remove the two screws on back side of the device.
1. Gently push the top cover of the router away from you.
2. Lift it up top cover from the bottom of the router.
3. Remove top cover from the device.
Use the Phillips #1 Screwdriver to remove the three screws on front side of the device.
1. Gently lift up inner metal shield from the bottom of the router.
2. Remove inner metal shield from the device (see the anchors on the picture).
1. Place your fingers on the levers at the two sides of the slot, and push open.
2. Firmly pull the release lever away from the module until the module pops up.
3. You can then remove the module from the module slot.
1. Use the Phillips #1 Screwdriver to remove the black screw.
2. Use the Phillips #1 Screwdriver to remove the silver screw as shown on picture.
Use the Phillips #1 Screwdriver to remove the two screws holding the motherboard.
1. Gently lift up the board to release plastic locks.
2. Gently pull the board away from backside panel (to release metal shielding locks around connectors).
3. Remove board from the case.
Parts and pieces:
Top cover
Inner metal shield cover
Bottom part of case with metal shielding
Motherboard
SHDSL Filter Module board
StrataFlash Memory Module
1 black screw, 1 silver long screw (1 is still on SHDSL Filter Module board), 7 silver screws
mini-PCI slot for WLAN card
DRAM socket for additional RAM Memory Module
Slot for additional StrataFlash Memory Module (4MB module installed)
Two connectors for SHDSL Filter Module board
3 Yorum
Sorry mate, that's not a CPU board but a SHDSL line filter. CPU is the biggest, center chip (freescale)
Thx for info! I will update my guide accordingly...
is it possible to add wireless capability to this router by installing a wifi card in the empty mini PCI slot?
