Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Commodore 1341 Joystick cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Commodore 1341 Joystick Teardown, Commodore 1341 Joystick Teardown: adım 1, 1 resimden 1.
    • Introduced in 1984, the Commodore 1341 joystick was designed for use with the Commodore range of computers including the Commodore 64, 128, VIC20 and Commodore Plus4.
    • This joystick connects to the retro computers using a 9 pin connection.
  2. Commodore 1341 Joystick Teardown: adım 2, 3 resimden 1. Commodore 1341 Joystick Teardown: adım 2, 3 resimden 2. Commodore 1341 Joystick Teardown: adım 2, 3 resimden 3.
    • The joystick is held together by five phillips head screws. One screw is located on the handle and the remaining four are under the base.
    • Once the screws have been removed you can pry the case apart using a flat head screw driver. Just be careful with the base as it is spring loaded and it can fly apart quite easily.
  3. Commodore 1341 Joystick Teardown: adım 3, 3 resimden 1. Commodore 1341 Joystick Teardown: adım 3, 3 resimden 2. Commodore 1341 Joystick Teardown: adım 3, 3 resimden 3.
    • You will need to desolder the fire button cables from the board.
    • Pry the case open but watch for the spring. There is also a rubber bung that sits beneath the black rocker shaft.
    • Desolder the cables from the main joystick board and remove all of the components.
    • Now you are ready to clean all of the joystick components and reassemble.
Andy Marsh
118 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 7,075
