Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Compaq iPaq Pocket PC 3765 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Compaq iPaq Pocket PC 3765 Teardown, Compaq iPaq Pocket PC 3765 Teardown: adım 1, 1 resimden 1.
    • an original ipaq from compaq not hp
    • the teardown is realatively simple (PS: simply is not always easy)
  2. Compaq iPaq Pocket PC 3765 Teardown: adım 2, 3 resimden 1. Compaq iPaq Pocket PC 3765 Teardown: adım 2, 3 resimden 2. Compaq iPaq Pocket PC 3765 Teardown: adım 2, 3 resimden 3.
    • There are four torx screws here
  3. Compaq iPaq Pocket PC 3765 Teardown: adım 3, 3 resimden 1. Compaq iPaq Pocket PC 3765 Teardown: adım 3, 3 resimden 2. Compaq iPaq Pocket PC 3765 Teardown: adım 3, 3 resimden 3.
    • Gently pry around the edges to release the cover
    • The battery is glued to the back cover be careful not to damage the fragile ribbon cable
    • fold the back under the front panel and carefully remove the battery connector
  4. Compaq iPaq Pocket PC 3765 Teardown: adım 4, 2 resimden 1. Compaq iPaq Pocket PC 3765 Teardown: adım 4, 2 resimden 2.
    • x
  5. Compaq iPaq Pocket PC 3765 Teardown: adım 5, 2 resimden 1. Compaq iPaq Pocket PC 3765 Teardown: adım 5, 2 resimden 2.
    • Disconnect the backlight
    • from the inverter
    • here is an Htc branded processor
    • be sure to pop up the black wire
    • remove the stylus ejector
  6. Compaq iPaq Pocket PC 3765 Teardown: adım 6, 1 resimden 1.
    • Gently pull on the top face while lifting the logic board (will require some force)
    • Be careful of the black wire running along the board
    • Disconnect the screen and digitizer cables being careful not to damage the cable or connector
  7. Compaq iPaq Pocket PC 3765 Teardown: adım 7, 1 resimden 1.
    • two Intel flash chips
  8. Compaq iPaq Pocket PC 3765 Teardown: adım 8, 3 resimden 1. Compaq iPaq Pocket PC 3765 Teardown: adım 8, 3 resimden 2. Compaq iPaq Pocket PC 3765 Teardown: adım 8, 3 resimden 3.
    • again putting pressure on the top panel lift the display out of the case
  9. Compaq iPaq Pocket PC 3765 Teardown: adım 9, 1 resimden 1.
    • an htc branded control board
    • (funny I thought it said compaq on the front?)
  10. Compaq iPaq Pocket PC 3765 Teardown: adım 10, 2 resimden 1. Compaq iPaq Pocket PC 3765 Teardown: adım 10, 2 resimden 2.
    • The final product (destroyed that is)
    • I used NO anti-static precautions, reassembled the device and after finaly getting the video cable to lock in it worked fine
    • PS: the touch panel worked But when i fixed the video cable i knocked it loose and didnt realize it and now i have to fix it (sigh)
josh9623
149 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 13
Son 30 gün: 25
Her zaman: 3,803
