Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. MP3 Player cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Cowon iAudio 7 8GB Teardown, Cowon iAudio 7 8GB Teardown: adım 1, 1 resimden 1.
    • The device in original condition.
  2. Cowon iAudio 7 8GB Teardown: adım 2, 1 resimden 1.
    • Removed the back of the case and the PCB screws. I had to drill open one of the case screws as it was stuck.
  3. Cowon iAudio 7 8GB Teardown: adım 3, 2 resimden 1. Cowon iAudio 7 8GB Teardown: adım 3, 2 resimden 2.
    • All parts disassembled. Second photo shows back side of the PCB.
    • As we can see, the device contains two Samsung 4GB flash chips along with a K4M28163PH-BG75 memory controller.
    • A Telechips TCC771L as main CPU.
    • A PCF50606HN battery/power management chip.
[deleted]
210 İtibar
1 Kılavuz yazıldı
3 Yorum
2011music my songs
Tong Thao - Yanıt
Hi! Could you, please, say what the type of display is there?
tikhonte - Yanıt
If anybody needs a new battery, try this: 3.7V polymer lithium battery 503060 or 053060
The number means the dimensions (5 x 30 x 60mm) The first number is often in 1/10mm
You’d need to solder the original cable to the battery or cables though.
Maybe you want to leave a comment here if this was helpful: adahnsplace.blogspot.com
Endre Sutus - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 26
Her zaman: 4,369
