Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Bu söküm üzerinde çalışılıyor – Son değişiklikleri görmek için düzenli olarak yenile!
Bu Teardown'da Kullanılan Aletler
Giriş
Learn to take apart a Dell 48x IDE Internal CD-ROM Drive
  1. Unscrew the top four screws.
    • Unscrew the top four screws.
    • Make sure that you don't mix up the screws.
    • They are different and you don't want to use the wrong screws.
    • Why would they do that?
  2. Take off the plate that you unscrewed last step
    • Take off the plate that you unscrewed last step
    • Put all the parts that you had taken off on the side so you do not lose them
  3. Unscrew the four screws on the next plate.
    • Unscrew the four screws on the next plate.
  4. 4- take off the top plate by lifting the back up and lightly pulling up.
    • 4- take off the top plate by lifting the back up and lightly pulling up.
    • the picture to the left is what it looks like after you take the plate off.
  5. 5-flip over and push the side tabs in and lift the bottom piece off (it might be hard to do but try not to force it off).
    • 5-flip over and push the side tabs in and lift the bottom piece off (it might be hard to do but try not to force it off).
  6. 6-push piece down and slide the disk piece out.
    • 6-push piece down and slide the disk piece out.
  7. 7-what is would look like.
    • 7-what is would look like.
  8. 8-unscrew the three screws on the  spin piece.
    • 8-unscrew the three screws on the spin piece.
  9. 9- unclip the chip in the front/back then lightly lift the piece up.
    • 9- unclip the chip in the front/back then lightly lift the piece up.
    • to put this device back together just do the steps backwards, nothing is hard to do.
    • be cautious because there are wires under the chip do don't pull hard or you are going to break it.
Brandon Frise
45 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,442
