Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Dell Inspiron 1750 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Dell Inspiron 1750 Teardown, Battery: adım 1, 2 resimden 1. Dell Inspiron 1750 Teardown, Battery: adım 1, 2 resimden 2.
    • Unplug the laptop before changing the battery to avoid electric shock.
    • Place the laptop on a flat stable surface.
    • Flip the laptop over so the underside is visible.
  2. Dell Inspiron 1750 Teardown: adım 2, 2 resimden 1. Dell Inspiron 1750 Teardown: adım 2, 2 resimden 2.
    • Locate the battery lock switch.
    • Slide the lock switch to the left (away from the lock symbol).
    • Slide the battery out away from the laptop.
  3. Dell Inspiron 1750 Teardown, Dell Inspiron 1750 Teardown: adım 3, 1 resimden 1.
    • Separate the screws by size and head type. Be sure to keep them in a safe place.
    • Remove the sixteen 2mm Phillips #00 screws from the bottom of the laptop.
    • Remove the two 2mm Phillips #0 screws from the hard drive port.
  4. Dell Inspiron 1750 Teardown: adım 4, 3 resimden 1. Dell Inspiron 1750 Teardown: adım 4, 3 resimden 2. Dell Inspiron 1750 Teardown: adım 4, 3 resimden 3.
    • Keep your hand pressed firmly on the back panel to prevent it from falling.
    • Flip the laptop over horizontally and open up the lid.
    • Insert the tip of the plastic opening tool into the upper left corner of the panel.
    • Keeping its tip under the top panel, slide the plastic opening tool around the panel until the panel is completely loose. Next gently remove the panel.
    • Remove the four 2mm Phillips #0 screws at the top of the keyboard.
    • Slide the plastic opening tool around the keyboard until the keyboard is completely loose. Gently remove the keyboard.
  5. Dell Inspiron 1750 Teardown: adım 5, 3 resimden 1. Dell Inspiron 1750 Teardown: adım 5, 3 resimden 2. Dell Inspiron 1750 Teardown: adım 5, 3 resimden 3.
    • Do not lift the keyboard completely free to avoid damaging its connections to the laptop interior.
    • Locate the small black latch attached to blue tape.
    • Lift the small latch with your finger and pull the blue tape from its port.
    • Slide the keyboard away from the mousepad and set it aside.
  6. Dell Inspiron 1750 Teardown: adım 6, 3 resimden 1. Dell Inspiron 1750 Teardown: adım 6, 3 resimden 2. Dell Inspiron 1750 Teardown: adım 6, 3 resimden 3.
    • Always pull wires from their plastic ends, not their cables, to avoid wire damage.
    • Locate the three wires in the top left corner of the metal panel.
    • Use the spudger to push the two cables out of their ports.
    • Pull the blue tab directly up to remove middle wire.
  7. Dell Inspiron 1750 Teardown: adım 7, 2 resimden 1. Dell Inspiron 1750 Teardown: adım 7, 2 resimden 2.
    • Remove the three 1mm Phillips #00 screws on the metal plate.
    • Lift the black cover and slide the blue tab away from the cover.
  8. Dell Inspiron 1750 Teardown: adım 8, 3 resimden 1. Dell Inspiron 1750 Teardown: adım 8, 3 resimden 2. Dell Inspiron 1750 Teardown: adım 8, 3 resimden 3.
    • Gently remove the three grey wires from the metal tabs.
    • Insert the tip of the plastic opening tool into the bottom left corner of the panel.
    • Gently lift off the top metal panel.
Jordan Nedbailo
687 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-3, Forte Spring 2014 Cal Poly, Team 6-3, Forte Spring 2014 üyesi
CPSU-FORTE-S14S6G3
5 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 50
Her zaman: 20,470
