Ana içeriğe geç
Bu söküm üzerinde çalışılıyor – Son değişiklikleri görmek için düzenli olarak yenile!
Bu Teardown'da Kullanılan Aletler
Giriş
This is a complete teardown of the Dell Quietkey SK-8000 Keyboard.
  1. Flip the keyboard over to expose 8 screws. Use a Phillips screwdriver to unscrew and remove each screw.
    • Flip the keyboard over to expose 8 screws.
    • Use a Phillips screwdriver to unscrew and remove each screw.
  2. Lift the keyboard upward from the bottom. Do not pull too hard when lifting the base. Be careful not to destroy the wires connecting to the base of the keyboard.
    • Lift the keyboard upward from the bottom.
    • Do not pull too hard when lifting the base. Be careful not to destroy the wires connecting to the base of the keyboard.
    • Use a Phillips screwdriver to remove the remaining ten screws on the aluminum plate.
  3. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  4. Carefully lift each part out. Each part should lift out very easily after the screws are removed. Carefully lift each part out. Each part should lift out very easily after the screws are removed. Carefully lift each part out. Each part should lift out very easily after the screws are removed.
    • Carefully lift each part out. Each part should lift out very easily after the screws are removed.
  5. The keyboard controller is seen to be a Siltek R4462.
    • The keyboard controller is seen to be a Siltek R4462.
Ion
470 İtibar
3 adet Kılavuz yazıldı
Takım
Cal Poly, Team 10-5, Green Fall 2015 Cal Poly, Team 10-5, Green Fall 2015 üyesi
CPSU-GREEN-F15S10G5
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 2
Son 30 Gün: 24
Her zaman: 260
