Neye ihtiyacın var
Remove the sticker and place it on a clean sticker-friendly surface.
Screw out the 9-mm screws using the J0 Bit.
Screw out the 4-mm screws holding the PCB in place. Use the J000 bit.
Now take out all the parts from the housing.
Remove the right/bottom 6mm screws.
Then the last 2 and the tightener screws. So you can pull it apart.
