Bu Teardown'da Kullanılan Aletler
Bu teardown bir tamir kılavuzu değildir. DualShock 4 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Begin by removing the screws  in the back of the controller. Begin by removing the screws  in the back of the controller. Begin by removing the screws  in the back of the controller.
    • Begin by removing the screws in the back of the controller.
  2. Remove the analog sticks and motors. Remove the analog sticks and motors.
    • Remove the analog sticks and motors.
  3. Remove the top layer PCB. The PCB must be popped out of place and then angled in such a way that the trigger buttons at the top of the controller slide out of their slots.
    • Remove the top layer PCB. The PCB must be popped out of place and then angled in such a way that the trigger buttons at the top of the controller slide out of their slots.
  4. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  5. Remove the second layer PCB. This simply pops out of place.
    • Remove the second layer PCB. This simply pops out of place.
  6. Flip over the second layer PCB. Remove the battery from its holder.
    • Flip over the second layer PCB. Remove the battery from its holder.
  7. Unscrew the two screws holding the light assembly together. Once the screws are undone, the parts of the assembly can be pulled out. Unscrew the two screws holding the light assembly together. Once the screws are undone, the parts of the assembly can be pulled out. Unscrew the two screws holding the light assembly together. Once the screws are undone, the parts of the assembly can be pulled out.
    • Unscrew the two screws holding the light assembly together. Once the screws are undone, the parts of the assembly can be pulled out.
  8. Unscrew the two screws holding down the USB module. Unscrew the two screws holding down the USB module.
    • Unscrew the two screws holding down the USB module.
Joshua Wong
205 İtibar
1 Kılavuz yazıldı
2 Yorum
Thanks this was so helpful because every time I do this I break it like literally break the plastic
nodachi Galaxy poison - Yanıt
Do you know where I can get broken PS4 controllers?
Chane Akwau Jones - Yanıt
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 Gün: 138
Son 30 Gün: 616
Her zaman: 3,074
