Ana içeriğe geç
Bu teardown bir tamir kılavuzu değildir. DualShock 4 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. DualShock 4 Teardown, Open the chassis of the controller: adım 1, 3 resimden 1. DualShock 4 Teardown, Open the chassis of the controller: adım 1, 3 resimden 2. DualShock 4 Teardown, Open the chassis of the controller: adım 1, 3 resimden 3.
    • Begin by removing the screws in the back of the controller.
  2. DualShock 4 Teardown, Remove analog sticks and motors: adım 2, 2 resimden 1. DualShock 4 Teardown, Remove analog sticks and motors: adım 2, 2 resimden 2.
    • Remove the analog sticks and motors.
  3. DualShock 4 Teardown, Remove the top layer PCB: adım 3, 1 resimden 1.
    • Remove the top layer PCB. The PCB must be popped out of place and then angled in such a way that the trigger buttons at the top of the controller slide out of their slots.
  4. DualShock 4 Teardown, Remove the second layer PCB: adım 4, 1 resimden 1.
    • Remove the second layer PCB. This simply pops out of place.
  5. DualShock 4 Teardown, Remove the battery: adım 5, 1 resimden 1.
    • Flip over the second layer PCB. Remove the battery from its holder.
  6. DualShock 4 Teardown, Remove the light assembly: adım 6, 3 resimden 1. DualShock 4 Teardown, Remove the light assembly: adım 6, 3 resimden 2. DualShock 4 Teardown, Remove the light assembly: adım 6, 3 resimden 3.
    • Unscrew the two screws holding the light assembly together. Once the screws are undone, the parts of the assembly can be pulled out.
  7. DualShock 4 Teardown, Remove the USB module: adım 7, 2 resimden 1. DualShock 4 Teardown, Remove the USB module: adım 7, 2 resimden 2.
    • Unscrew the two screws holding down the USB module.
Joshua Wong
265 İtibar
1 Kılavuz yazıldı
6 Comments
Thanks this was so helpful because every time I do this I break it like literally break the plastic
nodachi Galaxy poison - Yanıt
Do you know where I can get broken PS4 controllers?
Chane Akwau Jones - Yanıt
it doesn’t come out like that. upon opening the chassis, everything is stuck to the top part of the controller, not the bottom part.
Dennis Hasford - Yanıt
First time fixing sticking buttons my triangle button and ps button stick hopefully this works and am able to put back together
Tkuball - Yanıt
This video on how to open a ps4 controller should help you too : https://youtu.be/9Chgw4sRTzs
Repair & Resell - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 20
Son 7 gün: 121
Son 30 gün: 602
Her zaman: 58,342
