Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Echo Dot 4. Generation cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Echo Dot 4th Generation Teardown, Open the bottom: adım 1, 3 resimden 1. Echo Dot 4th Generation Teardown, Open the bottom: adım 1, 3 resimden 2. Echo Dot 4th Generation Teardown, Open the bottom: adım 1, 3 resimden 3.
    • Get under the bottom layer with something thin and pull it off. You might need to use quite a force as it's glued pretty well.
  2. Echo Dot 4th Generation Teardown, Loosen screws: adım 2, 2 resimden 1. Echo Dot 4th Generation Teardown, Loosen screws: adım 2, 2 resimden 2.
    • Take the screws out with torx 6. A T5 might work as well.
  3. Echo Dot 4th Generation Teardown, Open it: adım 3, 3 resimden 1. Echo Dot 4th Generation Teardown, Open it: adım 3, 3 resimden 2. Echo Dot 4th Generation Teardown, Open it: adım 3, 3 resimden 3.
    • Open the device.
    • The top part is housing the speaker with all boards and components.
  4. Echo Dot 4th Generation Teardown, Take out the mainboard screws: adım 4, 1 resimden 1.
    • Take out the mainboard screws with a torx 5.
  5. Echo Dot 4th Generation Teardown, Lift the mainboard.: adım 5, 3 resimden 1. Echo Dot 4th Generation Teardown, Lift the mainboard.: adım 5, 3 resimden 2. Echo Dot 4th Generation Teardown, Lift the mainboard.: adım 5, 3 resimden 3.
    • Be careful by lifting the mainboard. The LED panel and the control board are still connected.
    • Open it from the side on the volume up button.
  6. Echo Dot 4th Generation Teardown, Unplug the connectors: adım 6, 3 resimden 1. Echo Dot 4th Generation Teardown, Unplug the connectors: adım 6, 3 resimden 2. Echo Dot 4th Generation Teardown, Unplug the connectors: adım 6, 3 resimden 3.
    • Take a spudger and lift the connector off. Careful! It opens from the oppesite site the the cable is going in.
  7. Echo Dot 4th Generation Teardown, Place the mainboard aside: adım 7, 1 resimden 1.
    • Best place is in the bottom part where it originaly sits.
  8. Echo Dot 4th Generation Teardown, Take out the speaker: adım 8, 3 resimden 1. Echo Dot 4th Generation Teardown, Take out the speaker: adım 8, 3 resimden 2. Echo Dot 4th Generation Teardown, Take out the speaker: adım 8, 3 resimden 3.
    • Open the four torx 8 screws.
    • Lift the speaker outside the speaker grill.
  9. Echo Dot 4th Generation Teardown, LED Panel: adım 9, 3 resimden 1. Echo Dot 4th Generation Teardown, LED Panel: adım 9, 3 resimden 2. Echo Dot 4th Generation Teardown, LED Panel: adım 9, 3 resimden 3.
    • Carefully pull the partially glued connector cable off.
    • Use a torx 6 or 5 to take out the two screws.
  10. Echo Dot 4th Generation Teardown, Take LED panel out: adım 10, 2 resimden 1. Echo Dot 4th Generation Teardown, Take LED panel out: adım 10, 2 resimden 2.
    • Pull it in the direction of the arrows to take the panel out.
  11. Echo Dot 4th Generation Teardown, Take out screws of control board: adım 11, 2 resimden 1. Echo Dot 4th Generation Teardown, Take out screws of control board: adım 11, 2 resimden 2.
    • Loosen the four screws.
  12. Echo Dot 4th Generation Teardown, Loosen glued cable: adım 12, 2 resimden 1. Echo Dot 4th Generation Teardown, Loosen glued cable: adım 12, 2 resimden 2.
    • Pull of the glued connector cable.
  13. Echo Dot 4th Generation Teardown, Take off the cable: adım 13, 3 resimden 1. Echo Dot 4th Generation Teardown, Take off the cable: adım 13, 3 resimden 2. Echo Dot 4th Generation Teardown, Take off the cable: adım 13, 3 resimden 3.
    • Lift the lock, which is again on the opposite side of the cable.
    • Beware pulling the cable out. Don't pull it up, pull it as low as you can. See the arrow.
    • Remember how the board is placed because there isn't much of a difference.
  14. Echo Dot 4th Generation Teardown, Lift the controller board: adım 14, 3 resimden 1. Echo Dot 4th Generation Teardown, Lift the controller board: adım 14, 3 resimden 2. Echo Dot 4th Generation Teardown, Lift the controller board: adım 14, 3 resimden 3.
    • As the controller board sits quite tight better use the flat side of a spudger to lift it off.
    • Use the leverage effect.
  15. Echo Dot 4th Generation Teardown, Closer look: adım 15, 3 resimden 1. Echo Dot 4th Generation Teardown, Closer look: adım 15, 3 resimden 2. Echo Dot 4th Generation Teardown, Closer look: adım 15, 3 resimden 3.
    • Thats the controller board.
    • On the other sid are the buttons. Remove the rubber cap.
  16. Echo Dot 4th Generation Teardown, Screws of the device: adım 16, 1 resimden 1.
    • The device uses three types of screws.
Simeon
512 İtibar
2 adet Kılavuz yazıldı
Bir Yorum
Has anyone firgured out what kind LED is used??
Helios - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 16
Son 7 gün: 54
Son 30 gün: 222
Her zaman: 5,969
