Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Miscellaneous Electronics cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown, Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 1, 2 resimden 1. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown, Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 1, 2 resimden 2.
    • The Emerson Research SmartSet alarm clock automatically sets the time through the power of black magic and voodoo when plugged in.
    • That pale blue display, while calming during the day, while be so bright as to make it nearly impossible to sleep at night.
    • That said, let’s tear it apart.
  2. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 2, 3 resimden 1. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 2, 3 resimden 2. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 2, 3 resimden 3.
    • Remove 5/16” screw and slide out battery tray.
    • Remove four 1” screws.
    • Note the address on the ID sticker. Maybe send them a Christmas card and see if they send one back.
  3. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 3, 1 resimden 1.
    • There is a ribbon and three wires connecting lid to bottom shell.
    • Carefully, pulling from front to rear, pull away lid from bottom shell and display cover.
    • Mark this ribbon as top. Or not. You know your powers of memory better than me.
    • Grip ribbon connector by corners (not wires) and pull straight back away from board connector.
  4. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 4, 3 resimden 1. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 4, 3 resimden 2. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 4, 3 resimden 3.
    • The speaker and chime wires are soldered to the board.
    • Gently lay lid flat. Imagine it’s a sandwich you don’t want to upset
    • Remove two 5/16” screws and two speaker brackets.
    • Remove four 5/16” screws from board.
    • Remove two more 5/16” screws from board.
    • Remove the board. Appreciate how easy everything’s been so far.
  5. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 5, 3 resimden 1. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 5, 3 resimden 2. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 5, 3 resimden 3.
    • This is the hardest part of the teardown. Take a shot. Meditate. Prepare.
    • Carefully heat the glue along the plastic frame of the speaker. It will be difficult to heat the glue without deforming the plastic frame, as gratuitous amounts of glue were used and the frame wilts at the mere suggestion of heat. For those of you who can shoot fine lasers from your eyes, this would be a fine time to utilize that skill.
    • Pull the speaker away. If you’re patient, you might be able to pull out the speaker without damaging the frame too badly. If patience eludes you, as soon as you apply heat, get something to use as a wedge, start prying, and pray for the best.
    • Carefully heat and remove chime. This is much easier to remove than the speaker.
  6. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 6, 1 resimden 1.
    • Once you pull away the Sleep/Snooze buttons away from lid, the lid is disassembled.
    • Congratulations. Hard part over.
  7. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 7, 2 resimden 1. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 7, 2 resimden 2.
    • Moving on to the bottom shell....
    • Mark ribbons, if desired. Left/Right, Tim/Tom—your choice.
    • Remove two ribbon connectors from board. Grip each ribbon connector by corners (not wires) and pull straight up and away from board connector.
  8. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 8, 2 resimden 1. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 8, 2 resimden 2.
    • Remove two 9/16” screws from power source.
    • Remove power source from bottom shell.
  9. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 9, 2 resimden 1. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 9, 2 resimden 2.
    • Remove three selector switches. They pull off easily. Note their locations. Or play Tetris later figuring out where they go.
  10. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 10, 2 resimden 1. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 10, 2 resimden 2.
    • Remove one selector switch...
    • ...and two thumb knobs.
  11. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 11, 2 resimden 1. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 11, 2 resimden 2.
    • Remove three 5/16” screws...
    • ...and two more 5/16” screws.
    • (I know you just removed those two thumb screws and switch shown in the picture. We all make mistakes. Deal with it.)
  12. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 12, 2 resimden 1. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 12, 2 resimden 2.
    • Don’t lift the board yet: there’s still a wire connected to the battery tray connector.
    • Rotate board so that two screws securing the display board are accessible.
    • Remove two 3/8” screws.
  13. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 13, 2 resimden 1. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 13, 2 resimden 2.
    • Slide main board and display board forward to access battery tray connector.
    • Remove 5/16” screw.
    • Remove battery tray connector by pulling the connector away from the bottom shell.
  14. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 14, 1 resimden 1.
    • Pull display cover and display board away from bottom shell and set aside.
  15. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 15, 2 resimden 1. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 15, 2 resimden 2.
    • Very carefully heat the bracket securing the radio frequency indicator LED assembly. You will likely not be able to do this without breaking it.
    • Pull out radio frequency indicator LED assembly.
    • Separate main board from the bottom shell.
  16. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 16, 2 resimden 1. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 16, 2 resimden 2.
    • Back to the display....
    • Pull away the reflective shield.
  17. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 17, 3 resimden 1. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 17, 3 resimden 2. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 17, 3 resimden 3.
    • Remove two 5/16” screws.
    • and two more 5/16” screws.
    • Separate the display cover from the display board.
  18. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 18, 1 resimden 1.
  19. Emerson Research Model CKS1850 “SmartSet” Alarm Clock Teardown: adım 19, 1 resimden 1.
    • You’re done. Drink a beer. (Or, if you have access to it, a tall glass of horchata.)
gjsmithemail
131 İtibar
1 Kılavuz yazıldı
4 Yorum
Hi
I have emerson smart clock cks3528.by mistake I plugged into 220v.now it's not working. Can it be repaired?Pl help.
Email walkerjohn467@gmail.com
Jayashree - Yanıt
I have a cks3516 can’t set time. Is the power coming out of transformer d.c.? Want to test it! Thinking might be capacitor or cold solder joint! Any help or schematic would be lots of help! This is the projection clock radio! Thank you!
Richard Hanson - Yanıt
What does suffix D mean on the label. I seen some of the same model without it on the label. Is there a hidden function for home security? Like a microphone or small camera hidden to watch the room its in?
Brian Mahr - Yanıt
My old clock still works, but not bright enough anymore. Can I alter the circuitry a bit?
Oto Rustandi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 27
Her zaman: 7,201
