Giriş
The guide will provide a detailed teardown guide from beginning to end.
Neye ihtiyacın var
Carefully remove the screws and place them aside.
As seen in the pictures, set the screwdriver on the edge of the cover and pry it out.
Remove sticker in order to open the plastic casing of the heater.
Apply pressure onto the sides of the switch while pushing it outwards.
Unscrew the four screws located in the rear of the device. Remove the fan.
Bir Yorum
I keep having problems with that little part that looks like a pen cap - white plastic. Is it a connector ou a fuse?
