Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Space Heater cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Essential Home HC-409 Teardown, Removed protective grill: adım 1, 3 resimden 1. Essential Home HC-409 Teardown, Removed protective grill: adım 1, 3 resimden 2. Essential Home HC-409 Teardown, Removed protective grill: adım 1, 3 resimden 3.
    • Remove the grill from corner to corner.
  2. Essential Home HC-409 Teardown, Unscrewed the four screws in the front of the heater: adım 2, 2 resimden 1. Essential Home HC-409 Teardown, Unscrewed the four screws in the front of the heater: adım 2, 2 resimden 2.
    • Carefully remove the screws and place them aside.
  3. Essential Home HC-409 Teardown, Removed filter cover on the back of the heater: adım 3, 3 resimden 1. Essential Home HC-409 Teardown, Removed filter cover on the back of the heater: adım 3, 3 resimden 2. Essential Home HC-409 Teardown, Removed filter cover on the back of the heater: adım 3, 3 resimden 3.
    • As seen in the pictures, set the screwdriver on the edge of the cover and pry it out.
  4. Essential Home HC-409 Teardown, Remove safety sticker: adım 4, 2 resimden 1. Essential Home HC-409 Teardown, Remove safety sticker: adım 4, 2 resimden 2.
    • Remove sticker in order to open the plastic casing of the heater.
  5. Essential Home HC-409 Teardown, Pry the product in half: adım 5, 2 resimden 1. Essential Home HC-409 Teardown, Pry the product in half: adım 5, 2 resimden 2.
    • Slowly and carefully pry the plastic casing.
  6. Essential Home HC-409 Teardown, Remove the switch: adım 6, 2 resimden 1. Essential Home HC-409 Teardown, Remove the switch: adım 6, 2 resimden 2.
    • Apply pressure onto the sides of the switch while pushing it outwards.
  7. Essential Home HC-409 Teardown, Remove fan: adım 7, 3 resimden 1. Essential Home HC-409 Teardown, Remove fan: adım 7, 3 resimden 2. Essential Home HC-409 Teardown, Remove fan: adım 7, 3 resimden 3.
    • Unscrew the four screws located in the rear of the device. Remove the fan.
Garland Poon
126 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 14-8, Forte Spring 2012 Cal Poly, Team 14-8, Forte Spring 2012 üyesi
CPSU-FORTE-S12S14G8
5 Üyeler
17 adet Kılavuz yazıldı
Bir Yorum
I keep having problems with that little part that looks like a pen cap - white plastic. Is it a connector ou a fuse?
Cristina S - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 1,452
