Giriş
A look inside the Facebook Portal TV.
Neye ihtiyacın var
Features:
Smart Camera and Smart Sound
Alexa Built-in
Easy to Disable Camera and to Disable Microphone with push of button or blocking camera lens
Video Calling via Facebook, and Messenger
120 Degrees Field of View
12.5MP Camera Resolution
Far-field 8-Microphone Array
At first there didn't seem to be way into this device
Flipping the device upside down, there was cover between the enclosure, and the base. Removing this cover revealed sixteen T5 screws
Removing the sixteen screws, only removed the base
There was still no obvious way into to the product
It was time to get the Spudger Tool out and test a few edges
Working along the front edge, it appeared that the face plate was glued or held in place with double stick tape
The Spudger Tool was use to loosen a gap along the face plate edge
A Jimmy Tool was used to further release face plate
With the face plate removed
we can see the led light pipe
we can also see the camera shut off switch
LED Light Pipe
At this point we close to getting into this device
Now we are confronted with eight more T5 Screws
Time to get the Spudger Tool out and pry along the face again
This face plate houses the camera and speaker
With the face plate pulled back, we are confronted with two more T5 screws in the very back of the unit on the left and right of the product
We are much closer now to opening up the unit and getting access to the electronics inside
As mentioned in the last step, there are two T5 screws in the back of the unit
Just when we thought we had all the screws removed, the switch on the side unit is stopping the electronics from being pulled out of the enclosure. It has two T2 screws holding it in place
Bu adımda kullanılan alet:Tweezers$4.99
We can now use tweezers to remove the speaker cable attaching the front panel to the rest of the enclosure.
Then we can slide out the metal enclosure that holds the electronics from the main enclosure
Now use we can use tweezers to flip up the flex cable lock latch to release the flex cable attached to the main electronics in the metal enclosure and outer body. As will be seen shortly, this cable goes to a microphone array PCB in top of the outer enclosure
Now with the outer enclosure removed, and the front plate removed we can work on opening up the metal enclosure that contains the main electronics
The metal enclosure is held together with eight T5 screws. Use a T5 tool to remove these screws
The metal enclosure is also held together on each outer end with a flexible sticker type antenna. These flexible antenna will have to be removed before the metal enclosure can be opened up
Unfortunately, removing the flexible antennas will destroy them. Since the antenna are flexible, and have adhesive use to hold them in place. However, It may be possible to remove the antennas and use some adhesive to hold them in place when putting the unit back together
Use tweezers to remove the flexible antennas on each end of the metal enclosure
With the metal enclosure screws removed, and the flexible antennas removed from each side of the metal enclosure, the metal enclosure can be opened to give us the first look at the electronics within
We also see that the metal enclosure is not meant for much RF Shielding as much as it is meant for cooling and weighting down the product.
The cooling is via a copper heat pipe
Before we can get a closer look at the electronics, we also need to remove the u.fl Antenna cables that attached to the main electronics board
A Spudger Tool can be used to pry up and off the Antenna cables from u.fl connectors
Now use a Spudger Tool to remove the main electronics board from the metal enclosure
Camera flex cable is also held in place via a thick plastic block attached to the main electronics PCB. This plastic block can be pulled away from the PCB
Now that we have the main electronics PCB removed, we turn our attention back to the small electronic PCB locate in the top of the main enclosure
As can be seen in the first step photos of this teardown, there are eight pin holes in the top of the main enclosure. These pin holes are for the microphone array. The holes pass sound to the eight MEMS Micrphones below the pin holes
On the opposite out side of the main enclosure, we see eight circle holes. These hole are covered on the inside by black tape
With the RF Shielding removed, we can take a closer look at the components on the PCB. The main SoC is underneath the Sk Hynix Memory, and not easy to access. Sk Hynix also makes image processors, so it could be their SoC/Imager. A number of parts could not be crossed referenced, if you have information on a part please leave it in the comments
FLH - could not cross reference
DSP Group D7A1C Audio DSP
Sk hynix H9Hknnncrmmuernmh LPDDR4 32GB 256Mx16 PC3733
Qualcom PM8998 Power Management IC (PMIC)
Qualcom WCN3990 - WiFi 2.4Ghz, 5Ghz, 2x2, Dual-band concurrent, 802.11ac
Qualcom 3C/485Z - could not cross, but may be Power Amplifiers for WiFi
AW9109 - could not cross, but may be an LED driver IC from Shanghai Awinic Technology
With the RF Shielding removed from the backside, we can take a closer look at the electronics on this side of the PCB. Also, a number of parts could not be crossed, so if you have information on a part please leave in the comments
8mB / +19C / 10 - could not cross reference
894A / A1 12 / +9228 - could not cross
Qualcom PMI8998 - Power Management IC. Used with PM8998 (other side of the PCB)
Sinopower - SM3337 - P-Channel MOFET
SanDisk Embedded 32GB Flash Disk
Qualcom PM8005 Power Management IC
8 Yorum
That's a beautiful processor
Step 5 has a mistake.
I assume the author meant to say, 8 t2 scews (where they said t5) - as the required tool list has a t2 listed… However, my portal tv had 8 t3 screws here, NOT t2!
What is the voltage and amperage for the power supply? Do you know the diameter of the barrel plug?
The power supply is 12v DC 2 amps. I too am looking for the barrel connector size. I want to replace the power supply with a POE adapter.
For what it’s worth when I measured the barrel connector in tool used to measure screw sizes it measured 2.78mm (7/64 in). I have no clue what the inner diameter is though.
Any help would be greatly appreciated.
