Giriş
You may have heard a lot about the new Fairphone 2—the small Dutch company has been making waves with its affordable, modular, conflict-free cell phone, and once again, we're one of the first to get our hands on their latest device. When we tore down the original Fairphone, we were pleased by its modularity and easy access. Today, we're excited to see what this second-generation, responsibly-designed device has in store for us. Join us as we join the movement!
Want the inside scoop on all the newest tech? Check us out on Facebook, Twitter, and Instagram to stay up-to-date with the latest news in the repair world.
Here we have the second generation of the Fairphone. It's grown in size and in style:
5" 1080p LCD display (446 ppi) with Gorilla Glass 3 protection
Qualcomm Snapdragon 801
2 GB LPDDR3 RAM
32 GB internal storage with expandable storage via MicroSD slot
2420 mAh user-removable lithium-ion battery
8 MP rear camera
Android 5.1 Lollipop
Measuring in at 143 × 73 × 11 mm, the Fairphone 2 is definitely a size up from the 1st generation.
At 168 g (20 grams of which is the case) the Fairphone 2 is only 6 grams heavier than the 1st gen.
We can already spot two SIM slots underneath the see-through case. Hooray flexibility!
What's that? A five pin connector that seemingly connects to nothing? We'll be looking into that later...
This phone is lovingly labeled "Designed to open." Music to our ears!
The first item on our agenda is the translucent rear case. It's snug and secure, but snaps off with no tools required.
Where's all the adhesive? Is this a dream? Slap. No, definitely not a dream.
"Remove battery before releasing screen" Is this a disassembly tip on the battery?
Nothing makes us happier than when manufacturers include repair instructions with their device, let alone on their device.
The lack of visible screws had us a little worried, but not for long thanks to these handily-labeled clips.
Removing the display assembly is simply a matter of flipping the switches and sliding the panel out.
On the midframe we find an array of pogo pins, their counter parts are on the back of the display assembly.
Immediately below the contact pads on the display assembly we take off the metal shield and see where the display connects to the breakout board.
Et voilà, we have the mainframe with three individually removable modules. Little icons next to each one indicate what they do:
Headphone jack, earpiece speaker, and front-facing camera module
Rear-facing camera module
Microphone module
We also discover a proud little map showing the sources of the conflict-free tin and tantalum used in the phone.
The modules are held together with Torx T5 screws—presumably to deter the casual user from delving too deep—but are still easy to open up.
We start with the top module: the front-facing camera pops right off thanks to a simple flex cable connector.
Spring contacts power the earpiece speaker, making for easy replacement of that as well.
The headphone jack, the final component, is soldered to the board. Fortunately, nothing major remains, so a replacement board should be pretty cheap.
Up next, the rear camera module.
Hopefully this unit could be upgraded in later years, à la Project Ara. Fingers crossed.
The camera itself is an 8 megapixel CMOS camera with a 1/3.2 inch sensor and an aperture of ƒ/2.2.
This module is built just like the others: a plastic case around an off-the-shelf component, connected to a pogo interface board via flex cable and connector.
One last module to crack open—while it's only marked with a microphone icon, there are actually quite a few components in here.
The vibration motor and loudspeaker are connected by spring contacts—more easily removed parts, yay!
The USB port and microphone are soldered to the board—not necessarily a bad thing, as a USB port requires some extra rigidity, and has significantly more pins than a speaker.
The time has come to delve deep into the heart of the Fairphone 2.
The metal shield plate, replete with useful icons, comes off first, revealing a heat spreader still hiding the exciting bits.
Along the way, we find an RF cable, that sends the radio signal along the side of the frame to the main antenna, and pluck it free.
Well isn't this a beauty? We're really digging the translucent plastic frame, showing off all of its embedded antennas and buttons—all of which connect to the motherboard by spring contacts.
And down on the tail there are those five pogo pins we saw earlier. This is actually a USB 2.0 device interface, with power input—ready for future expansions and fancier cases.
And now for the tech section.
Samsung KLMBG4WEBC 32 GB eMMC NAND Flash
Qualcomm WCN3680B Wi-Fi 802.11ac Bluetooth Combo (Based on information from the Fairphone team!)
STMicroelectronics LSM330DLC 6-Axis Accelerometer + Gyroscope
AKM Semiconductor AKM8963C 3-axis Electronic Compass
Texas Instruments DRV2603 Haptic Driver
Qorvo Antenna Switch
On the backside we find a lot more:
Samsung K3QF2F20EM-QGCF 2 GB LPDDR3 RAM, layered on top of the Qualcomm Snapdragon 801 MSM8974AB
Qualcomm WTR1625L RF Receiver (similar to iPhone 6)
RF Micro Device RF7389EU Multimode Multiband Power Amplifier Module
Qualcomm QFE1100 Envelope Tracking Power Management
Qualcomm PM8841 PMIC
Qualcomm WCD9320 Audio Codec
Qorvo RF1496A SP12T Antenna Switch
Fairphone 2 Repairability Score: 10 out of 10 (10 is easiest to repair)
The LCD and cover glass are fused, simplifying removal, but significantly increasing the cost of replacement.
The most commonly failing components, battery and display, can be replaced without tools.
Internal modules are secured with Phillips #0 screws and simple spring connectors.
Individual modules can be opened, and many components can be individually replaced.
All buttons and cables are easily accessible. Spring contacts allow for future upgrades and easy component swaps.
In addition to the in-phone icons and instructions, the Fairphone 2 will ship with repair documentation built-in.
19 Comments
Hi people, I am a volunteer in the Repair Café of Deventer and we are very excited about the new Fairphone2 because it showcases what we are working for: Repairable design. We are with over 300 Repair Café's in Holland now and promoting the Fairphone is one of the things I like to do. I cannot wait to receive mine, should be end of this month. So I can take it to Paris on the 12th Decmber for the big Climate March. Super glad and proud with Fiarphone, they deserve 10/10 score all the way!
Aside from making the phone thinner, fusing the display and digitizer eliminates the issue of dust infiltration (specks of crap under the glass that just can't be cleaned off) which is a warranty/service concern on devices where the two are separate. The combination is also more rigid, providing a subjectively better (firmer) "feel" when the user taps the screen. It's also, all else equal, more resilient against impact or drop damage. From an engineering standpoint, the case can easily be made that these advantages outweigh the potentially increased repair cost, especially since the fused glass is less likely to break to begin with.
