Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Fitbit Zip cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Fitbit Zip Teardown, Fitbit Zip Teardown: adım 1, 3 resimden 1. Fitbit Zip Teardown, Fitbit Zip Teardown: adım 1, 3 resimden 2. Fitbit Zip Teardown, Fitbit Zip Teardown: adım 1, 3 resimden 3.
    • Use your iFixit Pro Tech Knife to slice and pry the different colored front and rear cases apart, as shown
  2. Fitbit Zip Teardown: adım 2, 2 resimden 1. Fitbit Zip Teardown: adım 2, 2 resimden 2.
    • Remove the logic board/display assembly from the rear case
  3. Fitbit Zip Teardown: adım 3, 2 resimden 1. Fitbit Zip Teardown: adım 3, 2 resimden 2.
    • Use your knife to slice off the bottom edge of the sticker found here on the rear of the board
  4. Fitbit Zip Teardown: adım 4, 3 resimden 1. Fitbit Zip Teardown: adım 4, 3 resimden 2. Fitbit Zip Teardown: adım 4, 3 resimden 3.
    • Use a spudger to gently pry the display away from the logic board
    • Pry softly in each corner of the display, under the black frame
  5. Fitbit Zip Teardown: adım 5, 1 resimden 1.
    • Seems to be it. The display doesn't appear to be separable from the logic board, sadly, making repairability completely out of the question.
Nathanael
977 İtibar
2 adet Kılavuz yazıldı
Ekip
Beautiful Savior Lutheran Church Beautiful Savior Lutheran Church üyesi
Business
1 Üye
3 adet Kılavuz yazıldı
2Kılavuz Yorumları
The display can be separated from the logic board, just pull it free from the logic board connector.
Yuri Silkin - Yanıt
My fitbit zip came apart at the seams. I decided to go ahead and clean the screen off since it was coming apart already and the screen looked dusty. Any ideas on how to put it back together? I goes back together and when I hold it everything functions, but I can't get it to stay together. Silicone? Glue? Any suggestions?
sweeney todd - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 2,297
