Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Flipper Zero cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Flipper Zero Teardown, Caution: adım 1, 1 resimden 1.
    • Do not use alcohol or alcohol containing cleaners, tissues, wipes, or sanitizers on the acrylic window! It can permanently damage it.
    • The top shell, the IR cover and the acrylic window are one solid part and can't be disassembled. (They pop out with a bit of force but wont go back in as well without some sort of glue)
    • The Flipper Zero only uses two types of screws:
    • Long screw size is M1.7x8
    • Short screw size is M1.7x4
  2. Flipper Zero Teardown, Remove the microSD card: adım 2, 1 resimden 1.
    • Eject the microSD card (if present) by pressing it with your fingernail.
  3. Flipper Zero Teardown, Remove the screws: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Phillips #0 Screwdriver
    $5.49
    • Use a PH0 screwdriver to unscrew the four long screws holding the back cover.
  4. Flipper Zero Teardown, Open the back cover: adım 4, 3 resimden 1. Flipper Zero Teardown, Open the back cover: adım 4, 3 resimden 2. Flipper Zero Teardown, Open the back cover: adım 4, 3 resimden 3.
    • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
    • Once the latches are released, you can remove the bottom cover.
  5. Flipper Zero Teardown, Lift the NFC antenna: adım 5, 1 resimden 1.
    iFixit Opening Picks (Set of 6)
    • The board with the NFC antenna is glued to the bottom cover with adhesive tape.
    • To remove the board, gently pry one of the edges of the board with a plastic pick to peel off the adhesive tape.
  6. Flipper Zero Teardown, Pull out the NFC antenna: adım 6, 2 resimden 1. Flipper Zero Teardown, Pull out the NFC antenna: adım 6, 2 resimden 2.
    • Gently pull out the rest of the board.
  7. Flipper Zero Teardown, Unscrew the chassis: adım 7, 1 resimden 1.
    $5.49
    • Use a PH0 screwdriver to unscrew the two short screws that are holding the chassis and top cover together.
  8. Flipper Zero Teardown, Seperate the chassis from the top cover: adım 8, 1 resimden 1.
    • Take the chassis out of the case.
  9. Flipper Zero Teardown, Disconnect the battery: adım 9, 1 resimden 1.
    • Disconnect the battery by prying the connector with a plastic pry tool and pulling it out.
    • Do not use a metal screwdriver when prying out battery connectors, if you do it may short the battery terminals and cause damage to the battery.
  10. Flipper Zero Teardown, Disconnect the ribbon cables: adım 10, 1 resimden 1.
    • Disconnect the large ribbon cable from the board. Use a plastic pick to lift the latch up to release the locks.
  11. Flipper Zero Teardown, Disconnect the ribbon cables: adım 11, 1 resimden 1.
    • Once the connectors are unlocked, carefully pull out the ribbon cables.
  12. Flipper Zero Teardown, Unscrew the iButton board: adım 12, 1 resimden 1.
    $5.49
    • Unscrew the short screw holding the iButton board in place using a PH0 screwdriver.
  13. Flipper Zero Teardown, Remove the iButton board: adım 13, 1 resimden 1.
    • Once the screw is removed, carefully remove the iButton board.
  14. Flipper Zero Teardown, Remove the cable from the iButton board: adım 14, 1 resimden 1.
    Flathead 1.5 mm Screwdriver
    $5.49
    • To disconnect the flat cable from the iButton board, use a flat screwdriver to carefully release the lock by pulling the latch up, then pulling gently on the ribbon cable.
  15. Flipper Zero Teardown, Remove the cable from the iButton board: adım 15, 1 resimden 1.
    • Once the connector is unlocked, gently pull the cable out of the connector.
  16. Flipper Zero Teardown, Release the battery chassis: adım 16, 2 resimden 1. Flipper Zero Teardown, Release the battery chassis: adım 16, 2 resimden 2.
    • To release the battery chassis, gently rock it back and forth while pulling the two parts apart.
  17. Flipper Zero Teardown, Remove the NFC RFID board: adım 17, 1 resimden 1.
    • To remove the NFC RFID board, release it from the latches in the sequence shown.
  18. Flipper Zero Teardown, Remove the NFC RFID board: adım 18, 1 resimden 1.
    • Release the board from the latches by pressing on the edge of the chassis near the specific latch in the specified sequence.
  19. Flipper Zero Teardown, Remove the vibration motor: adım 19, 2 resimden 1. Flipper Zero Teardown, Remove the vibration motor: adım 19, 2 resimden 2.
    • Take out the vibration motor.
  20. Flipper Zero Teardown, Unscrew the lace mount: adım 20, 1 resimden 1.
    $5.49
    • To remove the lace mount, use a PH0 screwdriver to unscrew the short screw that is securing it in place.
  21. Flipper Zero Teardown, Remove the lace mount: adım 21, 1 resimden 1.
    • Remove the lace mount from the chassis.
  22. Flipper Zero Teardown, Remove the battery: adım 22, 1 resimden 1.
    • The battery is attached to the chassis with double-sided tape. To remove it, use a plastic pick to gently peel the battery off the chassis.
    • Caution: Don't jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
  23. Flipper Zero Teardown, Remove the battery: adım 23, 2 resimden 1. Flipper Zero Teardown, Remove the battery: adım 23, 2 resimden 2.
    • Remove the battery from the chassis.
  24. Flipper Zero Teardown, Remove the ribbon cable: adım 24, 1 resimden 1.
    • Use a plastic pick to lift the latch up to unlock the connector.
  25. Flipper Zero Teardown, Remove the ribbon cable: adım 25, 1 resimden 1.
    • Pull the flat cable out.
  26. Flipper Zero Teardown, Unscrew the the button chassis: adım 26, 1 resimden 1.
    $5.49
    • Unscrew the two short screws holding the button chassis using a PH0 screwdriver.
  27. Flipper Zero Teardown, Separate the button chassis: adım 27, 1 resimden 1.
    • To disconnect the button chassis and the board, press the latch on the side shown below.
  28. Flipper Zero Teardown, Remove the button chassis: adım 28, 2 resimden 1. Flipper Zero Teardown, Remove the button chassis: adım 28, 2 resimden 2.
    • Remove the button chassis.
  29. Flipper Zero Teardown, Disconnect the screen: adım 29, 1 resimden 1.
    • Disconnect the screen ribbon cable from the board. Use a plastic pick to lift the latch up to open the lock.
  30. Flipper Zero Teardown, Disconnect the screen: adım 30, 1 resimden 1.
    • Remove the cable from the board.
  31. Flipper Zero Teardown, Desolder the screen: adım 31, 1 resimden 1.
    • To remove the screen you need to desolder two contacts.
    • Be careful during this step not to accidentally melt or desolder other nearby components.
  32. Flipper Zero Teardown, Remove the buttons: adım 32, 1 resimden 1.
    • To remove the buttons you need to release the latches.
    • OK
    • D-pad
    • Back
    • The central button (OK) is removed after the navigation button (D-pad)
  33. Flipper Zero Teardown, Remove the buttons: adım 33, 1 resimden 1.
    $5.49
    • Release the latches with a flat screwdriver. You need to be careful with the springs under the buttons.
  34. Flipper Zero Teardown, Remove the light guide: adım 34, 1 resimden 1.
    $5.49
  35. Flipper Zero Teardown, Remove the light guide: adım 35, 2 resimden 1. Flipper Zero Teardown, Remove the light guide: adım 35, 2 resimden 2.
    • Pull the light guide out from the inside of the chassis.
  36. Flipper Zero Teardown, Finish: adım 36, 1 resimden 1.
    • Here you can see all the parts laid out together.
Flipper Devices
685 İtibar
1 Kılavuz yazıldı
13 Yorum
I'd say, that long screws requires PH1 screwdriver.
Evge Key - Yanıt
Agree with Evge, when I read "PH0" I picked mine but they wouldn't quite fit. I had to use a PH1 (1.2 to be exact, according to toolset casing) to be able to unscrew the chasis and get to the battery (I had to only remove and plug back the battery cable to fix my problem)
João Ciocca - Yanıt
Careful with those screws. They are not great quality and strip easily.
andy cooper - Yanıt
Yeah, I have run into the same issue. The screw securing my IR/iButton board sheered in half! I cant remove the bottom part since its flush with the socket, but the board seems to be alright without it and is still in place since the chassis supports it. I still need to find a way to get it out :)
SkidFace -
Do you know what kind of these screws are?
Gugo - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 40
Son 7 gün: 229
Son 30 gün: 958
Her zaman: 48,324
